Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help, odd transmission grind
Old Jun 16, 2011 | 08:56 PM
beserious24's Avatar
Default Help, odd transmission grind
I'm not sure what to make of it, but I have very little knowledge diagnosing transmissions. I have a 95 Del Sol with the stock d15b7 and matching transmission. So far, I've had no trouble with pop outs, finding gears or even grinding. However, when in gear, usually 1st-3rd, there is some sort of grinding noise. Can anyone make any sense of it? I'm sure its probably obvious to someone.
Old Jun 17, 2011 | 06:54 AM
David @ Synchrotech's Avatar
Default Re: Help, odd transmission grind
A bad mainshaft bearing is very common on this transmission. See if it makes noise in neutral (at a stop) with the clutch out and the noise goes away when the pedal is depressed. If it does, it is the bearing.
Old Jun 17, 2011 | 07:51 AM
How detrimental is this? Is the transmission on it's way out or will it just make the noise for the remainder that I keep it?
Old Jun 17, 2011 | 01:08 PM
If it's the input bearing on the mainshaft, the seal will start leaking, and eventually the trans will self destruct.
Tking10
Sep 1, 2011 11:00 AM
b20beast83
Jan 12, 2009 01:39 PM
Hondaciv95VX
17
Dec 18, 2006 08:11 AM
ghatch
Sep 6, 2005 09:28 PM
PureBlood
Sep 30, 2002 11:40 AM
