Obd1 conversion runs terrible
Old Jun 16, 2011 | 07:30 PM
zrickety's Avatar
Default Obd1 conversion runs terrible
So i finally got all the obd1 parts on my b16 crx. New conversion harness, new 4-wire o2, new dizzy, new phearable.net chip, and an obd1 pr3.
Unfortunately, it sucks. Car hesitates and bogs throughout the revs, with the occasional misfire at low rpm. No codes, and everything appears to be working. My ecu came with a gsr map, I tried that today and got a CEL for codes 2 and 23. I know 23 is the knock sensor and I assume it's because it was the wrong map. I emailed phearable and they were no help. I'm ready to put all my old parts on because it was running great. Any ideas??
Old Jun 16, 2011 | 09:17 PM
rstchris's Avatar
Default Re: Obd1 conversion runs terrible
Try a known good ecu and check fuel pressure. Timing is set?
Old Jun 17, 2011 | 09:24 AM
zrickety's Avatar
i don't have another ecu, but i will ask around. yes, timing is set.
Old Jun 17, 2011 | 01:41 PM
flipkc's Avatar
Sounds like the conversion harness may be faulty? Or try another ECU that is known to be good?
Old Jun 17, 2011 | 02:00 PM
zrickety's Avatar
yeah it's a zerg industries conversion harness. it's my number 1 suspect now, i'm going through it and checking things with a multimeter.
Old Jun 18, 2011 | 12:18 PM
zrickety's Avatar
well i connected the extra grounds on the conversion harness and tried a different chip. car is running better.
thumbs down for phearable.net...
prionailurus
Mar 25, 2008 12:28 AM
spooncvc
32
Dec 27, 2007 01:51 AM
Arvid
Jul 3, 2005 07:37 PM
