serious compression issue
Old Jun 16, 2011 | 09:54 AM
nelson9994's Avatar
Default serious compression issue
okay guys.
im building an allmotor 82mm gsr...
I did a 1 layer (middle) HG with copper spray yesterday
Today, I find out the head was resurfaced 7 thousandths... the block was also resurfaced IDK how much.
I'm using pr3 pistons with flat valves...
I wanted around 12:4 comp. Now I think I'm at 12:8.
What do you guys think? I want it to make as much power as possible but I want it to be reliable at 93 octane since it's my DD.
With a 3 layer HG and regular valves comp should be at 11:5.
I'm scared is above and now I have to change the HG. I can always add the other layer but since I copper sprayed it I think I may have to buy a new one.
Old Jun 16, 2011 | 02:25 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: serious compression issue
Have your combustion chambers CC'd to better determine what your compression ratio will be with various gasket thicknesses. That's the only way to really know.
Old Jun 16, 2011 | 06:21 PM
nelson9994's Avatar
I just went ahead and did the top and bottom layer. so now I'm running a two layer. had to take the cams and all off again.
Old Jun 16, 2011 | 08:31 PM
UncleD's Avatar
Aren't you suppose to know these things before you build a motor?
Old Jun 16, 2011 | 09:34 PM
nelson9994's Avatar
lol... yeah man. for some reason I thought I would be at 12:4... I just re did the compression and all with the zeals calculator... with the .007 mill. and unknown block deck I set it at .10. giving the block .003 just in case. it puts me at 12:1... putting me at 12:4 with the flat valves. I should be good now on 93 octane.
Dr.Honda
Oct 22, 2007 06:22 AM
CXtypeR
Dec 9, 2006 03:05 AM
PM-Performance
Aug 8, 2003 11:05 AM
NightHawkC5
Feb 23, 2003 09:02 PM
PSU-TEG
Aug 5, 2002 05:56 AM
