help with my zc engine asap
i bought a zc dual head engine for my crx. but it needs a dizzy, both axles, intakemanifold, and motor mounts, and shift links, i was wonderin if i can get or use parts from a diff engine like a ls or b20 or d series??? if posible wat engine and wat year
That's not entirely true. Some parts are interchangeable with the 88-91 Si engine but not all of them.
distributor-89 Integra
both axles-depends on which transmission you're using
intake manifold-89 Integra shares the flange shape/pattern but the manifold is not exactly the same
motor mounts-stock mounts should work just fine if it is the later DOHC ZC (H emblem on exhaust side of valve cover)
shift linkage-stock should be just fine
Try looking in the FAQ or google "ZCR" for specifics.
91CRX_zc
Mar 30, 2007 06:12 AM
