D16A6 Timing Diagrams
Old Jun 15, 2011 | 04:11 PM
1990edsedan's Avatar
Icon6 D16A6 Timing Diagrams
Okay..
which one to abide by?
This from Honda Factory Manual:
Taken from this manual:
or
This from Chilton/Dayco/Helms manual:
Old Jun 15, 2011 | 04:23 PM
Default Re: D16A6 Timing Diagrams
D16A6 = SI
The first image is from my factory EF manual. Only two engines in that manual - D16A6 and DOHC ZC.
Old Jun 15, 2011 | 04:30 PM
evanguy's Avatar
why would you use anything but the Factory Honda Manual
Old Jun 15, 2011 | 04:37 PM
Ok, then riddle me this:
This is also from another Honda Factory Manual.
So which one to actually believe?
Old Jun 16, 2011 | 03:40 AM
evanguy's Avatar
do it how ever you want its all the same just different looking pics.
you line the cam gear with the word up facing up and both the lines even with the top of the head
then set your white dot on the crank pully to lined up with the marks on your timing cover
slide your timing belt on and adjust it to tite with the adjuster.
put the cover back on and drive your car.
every set of pics up there say to do that nothing different. its just the first honda pic showes it the clearest.
Old Jun 16, 2011 | 05:11 AM
Jockone's Avatar
First pic is 1.6 Si engine and second pic shows 1.5 Dx and Hf engines.
Old Jun 16, 2011 | 08:02 AM
No guys, read it carefully. Pic 1 is for SI. Pic 2 has HF/DX and SI, Pic 3 is the same - DX/HF and 1.6 SI..Just showing what mis-information provided even by the factory..
Old Jun 16, 2011 | 11:50 AM
Cameron R's Avatar
No it's not. Pic 1 does not say 1.6 or Si.
Old Jun 16, 2011 | 11:59 AM
DCRB's Avatar
the second pic is for vtec engines. o/p, you align the two lines up with the head and the lone white mark on the crank pully with the timing pointer then put the belt on
Old Jun 16, 2011 | 01:24 PM
I dunno, I posted the cover of the manual. Civic Coupe CRX. Was for 1988 models. The manual only shows 2 engines. SOHC D16A6 and DOHC D16A8/9.
Here's the spec page:
That should make it abundantly clear.
And as to being Vtec - here's the spec page that the manual I took image 2 from covers:
And as you see, No Vtec models. Note:D16Z2 = D16A6.
It is just odd that the factory would issue such information. If I timed my d16A6 the same in image one, it would run like steamed turd..
Grey_Matter
Oct 12, 2010 12:16 AM
I Am White
Mar 21, 2010 10:06 AM
Catch 22
19
Jan 13, 2003 09:20 AM
Stew Pidasso
Jun 21, 2002 09:44 AM
