Setting up injector dead times s300
Old Jun 14, 2011 | 09:51 PM
550whpcivic's Avatar
Default Setting up injector dead times s300
There 12.5 ohms and 1.00ms at 14volts. Can anyone show or tell me how to put that in? 1200cc fiveomotorsports ev14 injectors and there bad *** bye the way.
Old Jun 15, 2011 | 05:03 PM
xenocron's Avatar
Default Re: Setting up injector dead times s300
So badass they only gave you one data point? Lol
If you look atbthe battery table in Hondata...it is a two dimensional table
Old Jun 15, 2011 | 05:08 PM
lol I called them and They said there printer or something was going crazy and didn't print the rest. They told me subtract 20% from 1.00 starting at 14v going down to Zero. Does that sound right?????
Old Jun 15, 2011 | 05:12 PM
xenocron's Avatar
Not at all...
In my experience Five-O injectors are garbage garbage garbage.
Sorry to rain on your parade.
Old Jun 15, 2011 | 05:13 PM
mtber's Avatar
Originally Posted by xenocron
Not at all...
Elaborate... I have never tried them.
Well there doing there job right now..lol Is there anyway you can point me in the right direction on dead times please
Old Jun 15, 2011 | 05:15 PM
Old Jun 15, 2011 | 05:22 PM
xenocron's Avatar
I'm on my iPhone, goto Parameters --> Fuel Trim (injector) and post a screen shot.
John, for one...I don't even think he flows stuff, yet alone matches them at one point with a flow bench. I swear to god on one set I saw on a car i tuned, I think he had two different sized injectors. Like three of the injectors were 310cc and one was 440cc.
Old Jun 15, 2011 | 05:25 PM
[IMG][/IMG]
Old Jun 15, 2011 | 05:29 PM
mtber's Avatar
I guess it is true, you get what you pay for? hahah
Old Jun 15, 2011 | 05:31 PM
xenocron's Avatar
See there you go...you should have multiple data points to input into that color table there.
Important from 8 volts all the way to 16 volts
Can you post the data sheet that came with your injectors as well?
Old Jun 15, 2011 | 05:32 PM
yes anything in particular you need to see? Mostly all it says is what the injectors flow at 3-3.5-4 bar
Old Jun 15, 2011 | 05:36 PM
xenocron's Avatar
Well it should have something that slightly looks like that Hondata table with multiple points for voltage and showing a value in milliseconds for the dead time at each of those points
Old Jun 15, 2011 | 05:45 PM
Nope none of that
Can't really see anything
Old Jun 15, 2011 | 05:48 PM
xenocron's Avatar
Well at higher voltages that 14, dead times should be slightly less. And at voltages less than 14, dead times should be higher
So your table is a little off...too bad they didn't give you the data you actually need here
Old Jun 15, 2011 | 05:50 PM
So lilttle off? So is there any way to dial them in?
Old Jun 15, 2011 | 06:05 PM
xenocron's Avatar
That's a little more than I can type out on this thing...but yes.
Turn on every accessory you can, and if your afrs stay the same as you turn these on or off, dead times are pretty close
Old Jun 15, 2011 | 06:13 PM
Thanks a million
Old Jun 16, 2011 | 08:45 PM
ok i'm stumped, when I turned everything on it got really rich so i'm starting to hate these things. Any way to find out the dead times?
Old Jun 17, 2011 | 06:14 AM
onefastrx7turbo's Avatar
no way to "guess" the dead times. If what people are saying is true and this shop doesnt even flow test them, then you are out of luck. check this data out from the injector dynamics website, those guys know more about fuel injectors than the OEM's do. They also supply you with all of the slope and offset data you need to install their injectors:
http://www.injectordynamics.com/
evosix
Engine Management and Tuning
Jun 4, 2016 12:06 PM
SpokaneSpeed
32
Aug 13, 2013 04:02 AM
Cantcatchme
Apr 14, 2012 09:45 PM
wade
Apr 3, 2009 02:03 AM
