fuse 32 keeps blowing in 2000 si
my brake lights work but my corner light, taillights and license plate light dont... i replaced the fuse and it blows the moment i turn on my corners... i unplugged the corners and put a new fuse and it still blew it so i know its not the corner lights... i did the same with the tail lights, unplugged them and put new fuse and blew the moment i turned on my corners... i dont see any shorted wires... in the rear end i replaced every bulb about 3 weeks ago... what could it be? thanks!
Start by checking the parking, taillight, and license plate bulb sockets for signs of damage. If you remove all parking, taillight, and license plate bulbs, does fuse 32 still blow?
did the fuse start blowing after you fix what ever other eletrical prob you had ????? and rember that a short to gound will alway before the load cuz if it was after the load it would just be ground
i removed the rear connector and it still blows... so its not the rear section... then i took out the headlights and unplugged the corner light plug and it still blows it the moment i turn on my parking lights... what else do i check?
