Blox suspension. Input?
LCA's do nothing other then release some unsprung weight...really not worth it. They look good though. Function 7 or OEM w/ES bushings, no other choices there IMHO.
Sway bar- Depends on how you want the car to handle...thats a personal preference. Will help reduce body roll greatly. Depending on the size of the bar you'll most likely need subframe reinforcement.
Camber kit(s)- Not needed unless your dropping moren than 2" or so.
Shock Tower Bars- Questionable, I use the Nuespeed bar in the front...I love it. Works well, better then my OEM unit.
I know the purpose of the parts, haha. Just wasn't sure what products you guys recommended. I'll post a pic of my car in a bit, to give you an idea of what I'm working with. I'm building a daily driven car, with the occasional track visits and spirited weekend driving.
-OEM LCA's w/Energy Suspension Bushings
-OEM Front sway bar (if your car doesn't have one)
-OEM ITR rear sway or something of the sort..somewhere between 19-22mm
-Subframe reinforcement.
-Hard Race Master bushing kit, replace all that nasty old stuff
Your set to jet sir.
-Koni/GC
Thanks for the input man. Camber adjustment is a must. Skunk2 and Blox are the only products I've really seen put to use locally, and I wasn't impressed with either.
Cheers
GL man.
Camber adjustment is not a "must."
I've been ~2.5" in the front and 2.25" in the rear for 9,000 miles now and I've yet to do a rotation and my tires look fine.
I drove my dumped civic in high school without a camber kit for 2 sets of tires, never had uneven wear. Hated the ride height on that car, but I never had wearing issues.
I have to think that people getting "camber wear" are the dumbasses who don't get their cars aligned after they change their ride height or bushings.
Generally blox is a lower quality product, that will require replacement much sooner then other companies. I can't speak on their coilovers, because I have no experience with them, however, I can say I would not buy them.
Their endlinks on the other hand, suck. Mine are less then a year old and need to be replaced.
K sport/D2 get the same treatment, junk.
For the camber kits, from what I have been SPC seems to be the best. I have heard great things about BC camber kits also. The Sk2 kits are a wash, between bad reviews and good ones.
I had a sk2 rear camber kit for about 2 months before I threw them out. Very noisy when hitting bumps, and the bushings weren't looking all to good. I would not use them again.
thehatchninja
10
Dec 23, 2002 12:08 AM
