Transmission & Drivetrain Gearboxes, Differentials, Clutches
Cable b16 tranny won't go into 4th
Old Jun 13, 2011 | 08:42 PM
alx_90ef's Avatar
Default Cable b16 tranny won't go into 4th
ok so i was given a b16 tranny that wont go into fourth but goes into every other gear ok. im assuming its a synchro problem. but how do i make sure its not a shifter fork problem?
Old Jun 13, 2011 | 10:22 PM
Gearspeed-Performance's Avatar
Default Re: Cable b16 tranny won't go into 4th
Either way you will need to get the transmission opened and inspected. Can be a synchro/synchro spring issue, worn sleeve/hub/gear, or shift change assembly just to name a few. Once you get it opened check everything out and go from there. Keep us posted..good luck!
Old Jun 14, 2011 | 09:51 AM
alx_90ef's Avatar
alright i am probably tearing it open tonight.
hybred-1
Jul 23, 2008 11:29 PM
bosco500
May 10, 2008 08:15 AM
dustin_crxsi
Jan 29, 2007 08:08 AM
