Can you use the JDM F20c Engine Harness on the USDM S2000?
I'm in the process of putting together an AP1 s2000 that has an extremely hacked up USDM harness. The engine is a built turbo set-up and will be running the AEM V2 EMS. I have compared the USDM vs JDM Harness and there are only 3 pins that are different. I am not worried about the VTEC or Air Pump wires (located on plug C) as I will be running the AEM EMS. The only different wire that I can see is on the 3rd plug that attaches to under the dashboard (light blue flat plug). The USDM harness uses a WHT/BLK wire in pin location #9 whereas the JDM harness does not have this wire.
Does anyone know what this wire is for? I have gone through the diagrams and it seems to be connector C303 but I cannot find any further information as far as wiring goes in my Helms manual. Has anybody else used a JDM harness on a USDM chassis?
Thanks!
Plug B as shown in the image above.
Thanks!
wizzards581
39
Mar 10, 2024 09:16 AM
eddiecut
Aug 17, 2003 07:39 PM
Houston Hatchback
Apr 14, 2003 05:29 PM
