Window problem with regulator/rivet. motor still works but wont stay on track
i have the door panel pulled off, and can hear/see the motor spinning. i stuck the gears for the window track into the gears for the motor/regulator and they catch but it dosnt stay in. i cant tell there was a rivet holding the track to the regulator cause i found it and it was bent from years of use and i was wondering if there is a way to make another piece to hold it in, if it is infact why its not working. or where can i buy the rivet piece itself?
is there a diagram that shows all the pieces so i can get a part number? or a diagram that shows inside the door to see the motor and track
When the motor goes up, does it want to go down on it's own? Double check the legs on the regulator. It may be missing a rivet.
99 coupe
yeah, like fall down
no cables
yes...
i dont need one, but more than likely whats gonna have to happen
yes...
rhdins
May 10, 2011 05:15 PM
