exhaust rattle
Old Jun 13, 2011 | 01:36 PM
Sw33t_SI's Avatar
Default exhaust rattle
i have a 2001 honda civic si. Im getting this rattle every time i slow down while in gear, sometimes when i am out of gear and making a turn. Its not a long noise, or anything that sounds like its grinding and it only happens when im slowing down and turning. i looked at the hangers today and they seem to be in place, i moved one a little bit because the exhaust was close to the chases, anyone have any ideas on what to look at?
Old Jun 13, 2011 | 02:32 PM
redm3turbo's Avatar
Default Re: exhaust rattle
heat shields? there is more then just 1, tho... front/back check them.
could be suspension bushings though also....check all the rubber in the suspension for tears/cracks/rips...
Old Jun 14, 2011 | 03:42 AM
Sw33t_SI's Avatar
didnt think about anything with the bushings. Ill look at those when i can get the car back in the air. Thanks
Old Jun 14, 2011 | 05:18 AM
Crashtestdummy's Avatar
I know the guts on my ls cat got broken/loose and they would rattle around inside the cat whenever i downshifted or got on it real hard. It was annoying and took me a while to figure out what it was
Old Jun 16, 2011 | 07:08 AM
Sw33t_SI's Avatar
its a brand new cat, haha had that problem happen a couple months ago. I got back under the RR and took the tire of moved it more to the center of the car seems to help. did have tape when we looked the second time so now i just have another reason to get back under the car haha
Old Jun 16, 2011 | 07:27 AM
BigMike0147's Avatar
I get a rattle when I make left turns because my exhaust touches my rear sway bar. The 2.5" pipe is really big with the lowered car and it doesn't leave much room to fit. I need to have it adjusted.
I don't mean to ramble, but this is something that you might want to check out as well.
jxkim89
Aug 30, 2006 01:12 PM
puertoroc7976
Jul 18, 2006 07:32 AM
IntegraLs94Cam
Oct 1, 2004 05:43 AM
acme
Jan 11, 2004 06:18 PM
ih8danoles
14
Feb 2, 2003 03:12 AM
