5th Gen Manual Clutch Bleed/Trans Fill
Old Jun 13, 2011 | 12:25 PM
4g4dcruisin's Avatar
Default 5th Gen Manual Clutch Bleed/Trans Fill
Like the title says, I need to do both of these things. Confused on what is the fill hole on the trans housing....
Also, i'm bleeding the clutch from the slave cylinder and no air is present, but the clutch just slams against the floor.
Old Jun 13, 2011 | 12:40 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: 5th Gen Manual Clutch Bleed/Trans Fill
Fill hole is about halfway up on the back side of the transmission housing - it looks identical to the drain hole. You'll want a funnel with a long tube to reach it from around the strut tower/fuse box area.
Old Jun 13, 2011 | 12:41 PM
Thought it was a 17mm head...the drain is a 3/8 hole.
Old Jun 13, 2011 | 01:32 PM
Anyone else?
Old Jun 13, 2011 | 05:24 PM
kd97accord's Avatar
i usually fill mine thru the side where the axles go in, i fill it with a rubber hose until it begins to drip out, it may not sound like the most reasonable way, but it works good.
Old Jun 14, 2011 | 12:29 AM
holmesnmanny's Avatar
Yes, that's correct, assuming you mean 3/8 inch drive bolt. You are only putting a 3/8 ratchet on it.
Old Jun 14, 2011 | 06:57 AM
Yea, thats right.
Old Jun 14, 2011 | 06:55 PM
nus_dogg's Avatar
Yup, 17mm bolt for refill hole & 3/8" rachet for drain hole.
Old Jun 14, 2011 | 08:07 PM
sickaccord's Avatar
did you ever find out what was causing ur pedal to go to the floor iv bleed mine till no air an then some just cant seem to figure it out some one help me
BrandonClaps
Feb 19, 2020 01:10 PM
tercelrcr
Feb 2, 2013 06:25 AM
4g4dcruisin
Jun 20, 2011 08:30 AM
zeroz
Aug 18, 2005 12:54 PM
