pie cutting exhaust?
Old Jun 13, 2011 | 10:36 AM
b18cya94's Avatar
Default pie cutting exhaust?
can someone tell me where to find the info out on learning to pie cut? i have to build my down pipe and i have right at 3in from the turbo to the a/c compressor and i need to make a sharp bend.. anyone have any ideas?
Old Jun 13, 2011 | 10:43 AM
HickamHatch's Avatar
Default Re: pie cutting exhaust?
It's just a matter of taking a straight piece of tubing and cutting it at a certain degree. You can make it as tight or as loose as you want. 7.5 degree cuts will equal 15 degree sections and that will take 6 pieces to make a 90 and etc..
Old Jun 13, 2011 | 10:52 AM
b18cya94's Avatar
so u make a 7.5 degree cut then spin the pipe around and make another 7.5 degree cut to make A pie? and keep going back and forth like that?
Old Jun 13, 2011 | 11:06 AM
russianvr4's Avatar
OG Fabricator
exactly, spin the pipe 180* after first cut and rinse/repeat
Old Jun 13, 2011 | 11:09 AM
exactly
Old Jun 13, 2011 | 11:18 AM
b18cya94's Avatar
Originally Posted by HickamHatch
exactly
ok how big should the smaller side of the pie be? or does it depend on how much bend u need?
Old Jun 13, 2011 | 11:27 AM
I usually go about a 1/4" on the small end. Seems to get into most tight spots.
Old Jun 13, 2011 | 11:41 AM
b18cya94's Avatar
thanks man.. uve been a great help.. i should be able to get it now.. i played around yesterday for a few hrs and got it close.. but i was just guessing.. ive built dp's and charge piping before using u-bends but never needed to make a tight bend like this before..
Old Jun 14, 2011 | 02:02 PM
welfarepc's Avatar
search "pie cut calculator" on google and find the first reply with an attached spread sheet. you will need something that can view xls excel files.
the calculator will let you choose your center line, and amount of pieces required.
for 3" i usually go with a 3" center line, and 4 pieces per 90. that way u can use only 2 22.5deg pieces to make a 45 if required.
it winds up being 11.25 degrees on the bandsaw and 1.75" long on the long side of the cut. remember, each pie piece has two angles, so 11.25+11.25 = 22.5 degrees total.
Old Jun 14, 2011 | 02:31 PM
russianvr4's Avatar
OG Fabricator
thats a really sharp angle!
Old Jun 14, 2011 | 07:39 PM
9bells's Avatar
OG Fabricator
Here is an example of a job I did that required it. I went with alot more pieces, for a smoother look.
I also stick around 1/4-3/8" on the small end.
I take a piece of angle iron, and mark straight down the tube. Then, measure the circumference with a sewing tape, and divide in 2. Mark this from your straight line in a few places, then draw a 2nd line with the angle iron on those marks. Those lines are now 180 apart, and make it easy to get your measurements right as you turn back and forth.
You can see the lines I marked on the aluminum test piece. They act as terrific line-up marks for getting a 90 without twist if that is what you need.
I'll try to snap a few pics as I have to do this again in a similar fashion on a 2011 vert camaro with a blower and custom hood.
Old Jun 14, 2011 | 08:11 PM
JDMCRX's Avatar
Like everyone stated . straight line on each side of the pipe cut flip 180 cut again. Ive done 1/16"-1/8" on the small side to get in some tight areas and it can be a PITA welding them due to the lack of material.
Nice work 9Bells
Old Jun 16, 2011 | 11:21 AM
sleepencivic's Avatar
buy them!!
http://www.maperformance.com/maperfo...-map-fab1.html
Old Jun 16, 2011 | 08:19 PM
JDMCRX's Avatar
**** that is cheap for that.
Originally Posted by sleepencivic
Old Jun 18, 2011 | 08:18 AM
I know thats why i posted it///
Old Jun 18, 2011 | 10:22 PM
javierb14's Avatar
Good info in here! Did a little work with some tight radius stainless today following tips posted.
Here's the part with cheated bends on tight CLRs
and with pie cuts
Old May 31, 2012 | 11:02 AM
SQ is the SQUAD's Avatar
http://www.motokarts.com/resources/p...calculator.xls
Old Jun 1, 2012 | 08:38 PM
wantboost's Avatar
Who is Mr Robot?
i spy a gti-r motor
Old Jun 5, 2012 | 12:07 AM
Boosted_B_Series's Avatar
10 degree pieces. Made these for a friend. Pie cut the dump just to make it match the dp.
These sure take a lot of time. Mandrel bends take I bet an 1/8 of the time.
I mainly do these for the practice. It can really help your consistency with the lighter gauge stuff.
Old Jun 17, 2012 | 12:22 PM
mikesrex's Avatar
check out the pipefitters blue book it will give you all sorts of methods for calculating stuff that pipefitters use that you can use when fabbing up stuff.
Old Jun 17, 2012 | 06:54 PM
B and B's Avatar
Loved
Community Favorite
wish i could cut something that smoothly..best I have is a reciprocating saw and that stainless destroys a blade after about three cuts
Old Mar 8, 2013 | 04:52 AM
Devon M's Avatar
A porta-ban is fairly cheap. A couple hundred dollars for a nice one. You can cut straight cuts easily with it.
Old Mar 9, 2013 | 12:57 AM
Sleeper.SEDAN's Avatar
I use a chop aw and love it.
Beautiful pie cuts. Never thought id say that
Old Mar 10, 2013 | 05:28 PM
1sick4g63's Avatar
You don't square off the pipe after each cut?
Old Mar 26, 2013 | 05:41 AM
SOCKinside's Avatar
great info on here
HellaFab
Welding / Fabrication
Sep 16, 2013 09:51 PM
Veggie Man
Jun 9, 2013 06:57 AM
mikeycivic
Dec 7, 2009 01:34 PM
dfoxengr
Apr 23, 2003 06:10 PM
