My car bogs, Need Help ASAP!
recently did a d15b swap into my civic hatch cx. it ran fine for a day or two then problems came in. when my motor is cold and i try to start it, itll bog. it idles high for a minuet then low to the point where its about to die. but when my engine is hot itll sart up without a problem. can it b a lose ground, vacumm lines or do i just need valve adjustments due to white smoke too? i heard my car can b burning rich on fuel? someone let me know what it can be, thanks.
White smoke is a coolant leak in the head. That's most likely a bad head gasket, you can try some radiator leak stop from autozone. As for bogging check vacuum lines, iacv, fitv, spark plugs, spark plug wires, distributor.
ep3man
13
Sep 12, 2009 02:21 PM
hatchydude
Apr 29, 2009 09:54 PM
ophdehEEzY
Mar 14, 2003 07:30 AM
