90-91 CRX part out + extra goodies (k-swap parts).
Parts are located in south florida. Will ship at buyers expense (prices do not include shipping).
Text/call - Reed 304-984-6632. Or e-mail OMGVtec@gmail.com. I will NOT check PMs. Any questions feel free to ask, or more info on parts or pics. ALL PRICES ARE OBO.
6 point top of the line chromoly roll cage. Best you can find. WILL NOT SHIP. - 800
rear trunk panels cut for a roll cage. - 30
Rear hatch with glass – 50
SI Dash - 50
SI Headliner – 40
Rear dome light trim – 10
Rear quarter trim pieces. 2 screw holes, one in each – 20
A Pillar trim pieces mint – 20
O **** handle – 5
Factory fuel pump - 10
Clutch cable - 20
DPFI throttle cable (was used on the k20) - 10
Practically brand new speed cable - 30
OEM EF fuse box - 20
CRX glove box (missing latch, includes dash bracket, felt wearing out) - 30
Steering column cover - 5
Manual pedal assembly – 50
Working headlight switch - 10
Under dash fuse box (doesnt include fuses) - 20
Passenger side door weather stripping/trim all in good shape - 30
Driver side door weather stripping/trim. one piece slightly ripped, but doesnt effect anything - 30
Rear hatch weather stripping, few rips but doesnt effect sealing. - 40
Outer driver and pass side manual mirrors. mint shape no problems. - 50
Manual window regulators (driver) - 30
Main relay (perfectly working shape) - 30
13/16th brake master cylinder - 30
Brake booster – 30
Factory fuel line from fire wall to filter (worked with the K20) - 10
Wiper cowl. MINT no cracks - 30
90-91 door glass. no scratches or any broken tabs. just dirty/over spray. Driver. - 40
OEM factory side skirts. MINT. no broken tabs - 80
Auto-Meter Monster Tach. Mint and works flawlessly - 50
Auto-Meter Phantom series Oil pressure with line - 30
SunPro temp gauge with line - 20
Volvo TD04H turbo (minimal shaft play healthy) - 100
Skunk2 dual bend shifter (needs new bearings as shown) - 60 (or 100 with skunk2 5 speed shift ***, no pics yet).
Custom 3inch short ram intake w/ filter (heavy duty stainless steel pipe) made by Fab Worx. - 50
Vent-shade window visors - 50
Lexan rear hatch panels - 100
Wings West RS body kit (all 6 pieces). Will NOT SHIP. way too heavy. made of polyurethane, not fiberglass. there are more pics of it on the car and off i will have up shortly. – 300
2007 Civic Ex muffler - 60
EG fan relay new in bag - 40
Takatta Harness. Expired in 2007 - 300
Electronic cutout QTP – 50
Gator 2.9 K-swap EF axles (1/2 shaft NOT included). Uses 32mm outer hubs. - 450
EFK1 mounts - 350
Cable to hydro conversion bracket - 100
CF VIS Hood - 220 shipped.
Not pictured:
K20a2 long block - 1500
6Speed tranny with comp stage 5 Clutch - 1000
Ep3 idler with belt - 125
k20a2 Alternator. 100
k20a2 Starter 100
Manual Rack – 80
SOLD:
Ignition switch mint, with key
CRX tail lights with pigtails and gaskets.
Amber corner lights
Driver side fender
Dash harness
Cabin harness
Pass side window
Pass side window regulator
Vacuum line
Cluster
Headlights
outer trim pieces
Wilwood brake kit
CRX OEM Fuel pump
rear disc brakes
SI Dash - 50
SI Headliner – 40
O **** handle – 5
Clutch cable - 20
Brake booster – 30
EFK1 mounts - 350
Not pictured:
k20a2 Starter 100
Manual Rack – 80
SOLD:
Amber corner lights
Driver side fender
Dash harness
Cabin harness
Pass side window
Vacuum line
Cluster
Headlights
outer trim pieces
Wilwood brake kit
CRX OEM Fuel pump
rear disc brakes
the door trim? as in the outside or the weather stripping? more specific please.
they are gone sorry.
mounts are sold.
no there is not unfortunately and i havnt taken the time to look at it and see what would be required to make something work. im gona look at it tomorrow tho and see what can be done.
are you still interested in the CF hood? ill do it for 110 shipped to you.
also headlights and outer trim pieces sold.
Bigreed
Sep 12, 2011 04:00 PM
Bigreed
Aug 30, 2011 03:41 PM
EJ1_Sleeper
Jul 20, 2011 06:43 AM
92integra_gs
Feb 6, 2007 05:39 PM
