COMPLERE
Old Jul 5, 2011 | 08:07 AM
Bigreed's Avatar
Default COMPLERE
Everything is for a 90-91 CRX unless otherwise stated. Parts are located in south florida. Will ship at buyers expense (prices do not include shipping).
Text/call - James 954-592-7191, or Reed 304-984-6632. Or e-mail Jcaines87@gmail.com or OMGVtec@gmail.com. I will check PMs frequently as well. Any questions feel free to ask, or more info on parts or pics. ALL PRICES ARE OBO.
6 point top of the line chromoly roll cage. 2 at the rear shock towers, 2 at the rear seat section, 2 in the front. Best you can find. WILL NOT SHIP. - 800
rear trunk panels cut for a roll cage. - 30
Rear hatch with glass – 50
SI Dash - 50
SI Headliner – 40
Rear dome light trim – 10
Rear quarter trim pieces. 2 screw holes, one in each – 20
A Pillar trim pieces mint – 20
O **** handle – 5
Factory fuel pump - 10
Clutch cable - 20
DPFI throttle cable (was used on the k20) - 10
Practically brand new speed cable - 30
OEM EF fuse box - 20
CRX glove box (missing latch, includes dash bracket, felt wearing out) - 30
Steering column cover - 5
Manual pedal assembly – 50
Working headlight switch - 10
All outer trim pieces (one is cracked, and none have tabs as shown) - 10
Full inner door assemblies (door latch, outer handles, and inner handles) - 20
Under dash fuse box (doesnt include fuses) - 20
Mint EF headlights - 50
Passenger side door weather stripping/trim all in good shape - 30
Driver side door weather stripping/trim. one piece slightly ripped, but doesnt effect anything - 30
Rear hatch weather stripping, few rips but doesnt effect sealing. - 40
Outer driver and pass side manual mirrors. mint shape no problems. - 50
Manual window regulators (driver) - 30
Main relay (perfectly working shape) - 30
13/16th brake master cylinder - 30
Brake booster – 30
Factory fuel line from fire wall to filter (worked with the K20) - 10
Wiper cowl. MINT no cracks - 30
90-91 door glass. no scratches or any broken tabs. just dirty/over spray. Driver and Pass. - 50 (or 40 each)
OEM factory side skirts. MINT. no broken tabs - 80
Auto-Meter Monster Tach. Mint and works flawlessly - 50
Auto-Meter Phantom series Oil pressure with line - 30
SunPro temp gauge with line - 20
Volvo TD04H turbo (minimal shaft play healthy) - 100
Skunk2 dual bend shifter (needs new bearings as shown) - 60 (or 100 with skunk2 5 speed shift ***, no pics yet).
Custom 3inch short ram intake w/ filter (heavy duty stainless steel pipe) made by Fab Worx. - 50
Vent-shade window visors - 50
Lexan rear hatch panels - 100
Wings West RS body kit (all 6 pieces). Will NOT SHIP. way too heavy. made of polyurethane, not fiberglass. there are more pics of it on the car and off i will have up shortly. – 300
VIS ZC style carbon fiber hood. needs work - 200
88-89 Hatchback rear quarter windows. MINT - 30 (or 20 each)
2007 Civic Ex muffler - 60
EG fan relay new in bag - 40
Wilwood super lite front kit with flat rotors on spindles ready to bolt on - 450
Takatta Harness. Expired in 2007 - 300
Electronic cutout QTP – 50
K-series Hydro to cable conversion - 100
DSS 2.9 K-swap axles (1/2 shaft NOT included). Uses 32mm outer hubs. - 450
EF K-swap HAsport mounts with brackets and 85A bushing durometer - 350
Shell is cut up
Not pictured:
K20a2 long block - 1500
6Speed tranny with comp stage 5 Clutch - 1000
Ep3 idler with belt - 125
k20a2 Alternator. 100
k20a2 Starter 100
Rear quarter windows – 80
Manual Rack – 80
SOLD:
Ignition switch mint, with key
CRX tail lights with pigtails and gaskets.
Amber corner lights
Driver side fender
Dash harness
Cabin harness
Fuel line with bango
SI Cluster
Vacuum line
Passenger side window regulator and track
Pending:
Wings West RS kit
Engine harness
Wilwoods (again)cc
Bigreed
Aug 30, 2011 03:41 PM
EJ1_Sleeper
Jul 20, 2011 06:43 AM
EJ1_Sleeper
