94 cx hatch CEL jump wire?? [location]
Trying to find the location of the two pin grey wire harness that you can jump to get the CEL to flash the code corresponding to the problem. Except i inverted my body like a gymnast and could not find it. What i found was a two pin brown wire harness that was next to what looked like an 8 pin wire harness.
I assumed this two pin grey wire harness should just be hanging but it wasn't...
I am making an assumption since this was a swapped engine and now has the P28 ecu for vtec that whom ever mounted the ECU trapped the harness behind it.
I've looked over this awesome thread to gather the knowledge i have now. [https://honda-tech.com/forums/showthread.php?t=1901557] Which will help a lot once i find the correct harness.
Let me know what you all think and confirm what i have said is correct.
Thanks ahead of time
Well the wires were not behind the ecu so I'm not finding them, i do have two wires hanging near my hood release they are blue and black though [just two wires with no clip and un spliced.]
Is their an alternate place that i can tap the wires to get the CEL to flash or is this the only way?
1 Cam Wonder
19
Oct 10, 2004 08:49 AM
cr00klyn718
Jul 13, 2003 10:59 AM
