d15b2/d16a6 head
Old Jun 12, 2011 | 04:18 PM
low&slowef's Avatar
Default d15b2/d16a6 head
i have a d 15b2 block and was wondering if i could put a d16a6 head on it i wanna do a mini me but with no v-tec is this posible if so what is needed to be done to make it run? also a question for you is it worth doing this?
Old Jun 12, 2011 | 04:49 PM
digitally_remastered's Avatar
Default Re: d15b2/d16a6 head
just swap the cam from the d16a6 head into the b2 head. nothing else is different.
Old Jun 13, 2011 | 04:39 AM
1990edsedan's Avatar
Yep. you can run either timing belt (from a B2 or A6) as they are only 1 tooth difference. You can run the set up as dpfi, or you can do the mpfi swap.
Old Jun 13, 2011 | 10:11 AM
low&slowef's Avatar
Ok thanks. For the info.
kauai96
Apr 8, 2024 12:41 PM
88EDHatch
Jan 29, 2010 05:25 PM
mikej94civex
Jan 11, 2010 02:20 PM
sde780
Aug 20, 2009 05:29 PM
xpurespeedx
Dec 7, 2002 10:35 PM
