bore size on oem headgasket?
Old Jun 12, 2011 | 03:47 PM
SR20S13's Avatar
Default bore size on oem headgasket?
whats the bore size on a OEM headgasket? I think its 82mm if so then its fine because my build will have 81.5mm pistons so i don't want a 81mm headgasket.
found it myself its 81.75mm should have looked deeper and just used google
Old Jun 12, 2011 | 04:19 PM
spoolie's Avatar
Default Re: bore size on oem headgasket?
Really guy??? What headgasket are we talking about?
Old Jun 12, 2011 | 04:21 PM
SR20S13's Avatar
do you read?
Old Jun 12, 2011 | 05:25 PM
MR.johnson's Avatar
Originally Posted by SR20S13
do you read?
um yeah, should we guess what head gasket,block, and head your using?
chill out. we cant read what you didn't type.
Old Jun 12, 2011 | 05:32 PM
SR20S13's Avatar
okay a b-series head gasket i figured since the only motor around 81mm was the b-series people might catch up on that but i guess not
Old Jun 12, 2011 | 05:35 PM
spoolie's Avatar
b18 or b20?
Old Jun 12, 2011 | 05:39 PM
MR.johnson's Avatar
so buy a damn gasket that matches your bore size or .5 bigger. whats the issue here?
Old Jun 12, 2011 | 05:44 PM
SR20S13's Avatar
Originally Posted by spoolie
b18 or b20?
really? a b20 has a 84mm so CLEARLY it won't ever use a 81 or 81.5mm bore headgasket
and i'd prefer a OEM head gasket i'd rather not buy a aftermarket one
Old Jun 12, 2011 | 05:46 PM
MR.johnson's Avatar
golden eagle is oem bro.
Old Jun 12, 2011 | 05:50 PM
MR.johnson's Avatar
http://www.fullblownmotorsports.net/...bbdb47bcd7842a
call them up, tell them what size you want.
Old Jun 12, 2011 | 06:08 PM
SR20S13's Avatar
never mind lock this found its 81.75mm
boostedblue23
Engine Machining & Assembly
Nov 2, 2018 09:50 AM
McCivic
May 25, 2009 10:09 AM
MOVE OVER
Dec 1, 2007 07:39 PM
onlinehost
Dec 9, 2005 02:40 PM
asubennett
Feb 3, 2005 07:31 AM
