Power steering pump noises
Old Jun 12, 2011 | 06:29 AM
itr1235's Avatar
Icon6 Power steering pump noises
today my power steering pump makes a whining noise upon start up could it be the belt or pump it self. if it is the pump, what interchangable pumps can be used. thanks
Old Jun 12, 2011 | 05:16 PM
SlapSmak's Avatar
Default Re: Power steering pump noises
fluid is low.. check that first
Old Jun 12, 2011 | 06:23 PM
itr1244's Avatar
i might have the same problem?
does it make supercharger kinda sound?
mine make that noise when i accelerate or revving the motor.. i hear it from driver side.
Old Jun 12, 2011 | 07:17 PM
blac00si's Avatar
Is the fluid level good..?
Jack up the car (on jackstands), top off the fluid, start the car, turn the wheels from side to side.
This fixed the noise problems I had on my teg.
Old Jun 12, 2011 | 08:29 PM
itr1235's Avatar
thanks for the responses, the fluid is full and yes the noise becomes louder at higher revs.
Old Jun 12, 2011 | 08:36 PM
itr1244's Avatar
i think i need a flush.. i only topped up the fluid .. never replaced it since 2001.... hmmm lol
Old Jun 13, 2011 | 03:59 AM
Ultraspeed DC2's Avatar
Mine made that when part of the system broke. The pump started to heat up to 400+ deg according to my laser? The line from the pump to the rack collapsed inside and the fluid was going nowhere.
Old Jun 13, 2011 | 05:33 AM
itr1235's Avatar
did you just replace the line and it worked?
Old Jun 13, 2011 | 07:15 AM
94rs-turbo's Avatar
you can rebuild your PS pump inexpensive to do yourseld, just seals and a bearing
bestofthe80s
May 30, 2017 09:57 PM
HondaFan_in_FL
Dec 31, 2012 05:50 PM
woainot
Dec 5, 2011 10:47 PM
cityofcaterpillars
Apr 27, 2010 11:49 AM
btran
Jul 29, 2004 09:16 AM
