Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic Ex - What to do with bad Input Shaft Bearing
Old Jun 12, 2011 | 05:41 AM
Marlin 444's Avatar
Default 2005 Civic Ex - What to do with bad Input Shaft Bearing
Hi,
I have a bad input shaft bearing in my manual trans. With the car in neutral and foot off the clutch, I get some grinding noise. And there is clicking noise too when I am driving, but only when I give it gas.
I talked to a couple of trans places and my options are:
1) find a used trans and have it installed
2) find a rebuilt trans and have it installed
3) have the shop rebiuld my trans
I have 115k on the car and need it to last 3 more years. The bearing started acting up at 85k with the clicking noise in gear.
What would you do? or what have you done with yours with a bad input shaft bearing?
Thanks,
Jeff
Old Jun 12, 2011 | 07:54 AM
toyomatt84's Avatar
Sanji
Default Re: 2005 Civic Ex - What to do with bad Input Shaft Bearing
I'd go with option "2" or "3", personally. Used transmissions can sit in lots for a while, so you may end up getting the same issue again within a shorter amount of time then you'd like.
drsab2000
Jan 26, 2019 05:59 PM
Hal9000
17
Jan 12, 2009 08:27 PM
1kleenef
Apr 1, 2008 05:04 AM
pinky5
Nov 12, 2007 04:10 AM
SlowPokeEg
Jun 13, 2006 05:34 PM
