Water leak in 91 hatch
I have been noticing a leak everytime i wash my car. It's in the hatch but im not sure where. All I know is when i first open the hatch the outer area around the opening is filled with soap and water. Then i noticed water leaking down the right side in the under side of the hatch tray. Any one have this problem or any ideas of how to fix it?
it seems these things always leak ive been trying to track mine down since ive owned it and still cant find where its coming from its leaking down the inside of the driver side c-pillar i checked my sunroof tube and its connected and not clogged
i had this problem in my old crx, so i decided to get in it and have my friend spray the hatch with the hose lol it worked and when i founf it, i cleaned the area really well, and used clear rtv, if you do it right you cant even see the rtv. hope this helps.
Check sunroof drain tubes for clogs. If you have an air compressor shoot some air up there to clear up clogs
Remove the interior around the leak area. Get inside car and have friend hose car down with water and check for leaks.
head458
Oct 20, 2009 05:38 PM
tommyboy
Sep 19, 2004 11:45 AM
