Could I have a T-stat stuck open?
Old Jun 11, 2011 | 11:52 PM
CaliforniaDad's Avatar
No-Traction = Fun
Default Could I have a T-stat stuck open?
I was driving home from work tonight when I happen to glance at my temp gauge "What The......" I'm thinking the thermostat is stuck open. When I sit at idle the temp goes up, but soon as I start moving down she goes.
Old Jun 12, 2011 | 12:44 AM
el crapitan's Avatar
Default Re: Could I have a T-stat stuck open?
check that your fan comes on at the appropriate time
Old Jun 12, 2011 | 03:18 AM
EnjoyTheRideDC2's Avatar
Do you have any modifications done to your cooling system at all?
Has your cluster been altered in any way? Looks like an R tach with a non-R temp gauge.
How far does your temp needle rise when you're at idle?
You may have a open T-Stat, but thats pretty low for the needle to be...
Old Jun 12, 2011 | 07:35 AM
No-Traction = Fun
Yep they sure do. When I got home I let the car sit at idle, the temp rose to normal and the fans kicked on and off.
Yes I have a 3 core aluminium radiator, running 60/20 mix coolent/water & water wetter additive. And yes I have the R tach with GSR everything else. Its been operating like normal for months, until last night.
Old Jun 12, 2011 | 07:46 AM
fcm's Avatar
fcm
Old Fart
Sounds like an open thermostat to me. 94
Old Jun 12, 2011 | 09:35 AM
sayanything's Avatar
^ same, i had this issue and the temp guage would just stay in that area of the pic you posted.
Old Jun 12, 2011 | 10:13 AM
oh, so it's not actually overheating? i thought when you said "it goes up", you meant it overheats. t-stat regulates max temperature. so if it's overcooling, it's gonna be the t-stat
Old Jun 12, 2011 | 10:33 AM
Likely open t-stat. The needle is lower on your gauge because of the radiator you are using. With that 3 core, you're running your DB way under temps on the highway.
Old Jun 12, 2011 | 03:18 PM
No-Traction = Fun
Yeah here is a picture I just took while driving into work today 4k @ 75-80mph with the A/C Kicking.
Old Jun 12, 2011 | 05:22 PM
fcm's Avatar
fcm
Old Fart
Wait, you said, "When I sit at idle the temp goes up, but soon as I start moving down she goes" so if you move faster [75-80MPH, with A/C on] the engine temp. goes up again? 94
Old Jun 12, 2011 | 05:40 PM
No-Traction = Fun
Yeah thats what it was doing last night. It was about 12:30 at night. It was cool last night. The first pic was taken last night. So today it was mid/hi 80's and thats were the temp was this afternoon. Very Very Very WEIRD
Old Jun 12, 2011 | 09:33 PM
mouab18c1's Avatar
Check your coolant level and replace the thermostat. It's a cheap fix.
Old Jun 12, 2011 | 09:42 PM
No-Traction = Fun
Yep, checked the coolant level before leaving to work. Level is perfect and coolant reservoir was perfect.
nicknack25
Feb 13, 2012 09:27 PM
bobryan
Dec 29, 2008 05:21 AM
danteisme
Feb 20, 2006 06:01 PM
99lspwr
Oct 25, 2004 06:17 AM
jman
Oct 12, 2002 08:20 PM
