Oil pan change advice please
Old Jun 11, 2011 | 10:19 PM
dgerej2's Avatar
Default Oil pan change advice please
My car is a 99 civic ex. I took off most of the bolts/screws for the job. I will be taking off the bottom part of the header next. Does anyone have any tips for my job? Is a new gasket a must? What kind of sealant should I use? Permetex/Gasket Maker/Silicone? What should I do about any sludge inside? What is the best way to clean it? Thanks
Old Jun 11, 2011 | 10:42 PM
civickiller's Avatar
Default Re: Oil pan change advice please
Get a new gasket and a tube of hondabond
I clean out my oil pans with brake clean
Old Jun 13, 2011 | 12:12 PM
Lewy. Dee Ayy's Avatar
Make sure you remove all old gasket from the bottom of the block and the top of the pan. it can be time consuming if you dont have a wire wheel but it can be done. and make sure there are no washers on any of the studs on off the block. they are from the old gasket and need to be removed or else it will leak again. and DO NOT OVER TQ gasket..iv seen it way to many times.
hondaman211
Jul 22, 2020 06:29 AM
pinoyboy204
29
Apr 28, 2017 07:14 PM
george34
Nov 9, 2016 09:44 PM
StreetRacinThug
Dec 21, 2006 08:44 AM
drumsy
Feb 6, 2002 12:18 AM
