rmf header and greddy turbo 3' catback
okay guys I have a 1.8 l na built gsr. I am now going for the exhaust. I have a rmf replica header and a 3 inch greddy turbo catback... how would I connect this? do I have to get a custom test pipe made by a muffler shop or what?
also I want to make my cometic headgasket a 2 layer. which layer do I remove?
yes, more than likely and you're better off modifying a stock headgasket by removing the middle layer after you drill out the rivets.
Top and bottom, you can spray the outside of the top and bottom (not where they join together) before you install it for extra insurance. The stock headgasket is 82mm bore fyi.
i could not find a 82mm stock hg anywhere. 81mm is stock and 81.5 is the biggest i ever saw i believe.
anyways I paid almost $100 for the cometic and I don't want to go out and buy another. can I go to 2 layers with this one also?
stock are bored to 82mm so that u can use them when going oversize...and get a 3 inche section online and cut it to length .....or just take it to an exhausut shop and get it done..
Sell your cometic as it may be thicker than stock, what is it? Just pick up a stock head gasket which are all 82mm bore incase the customer wants to go oversize on the bores like you are.
as of right now. I will be keeping the cometic. I am planning on removing 2 layers and maybe keep a one layer. I have a resurfaced head and block (first time for both)... pr3 pistons (82mm) and flat valves in a complete gsr motor. do you guys think it is safe to do a 1 layer? what will my comp be at. it says 12.2 (compression calculator) but thats not adding the resurface and the flat valves. what do you guys think?
Tong.Y
Jun 17, 2011 04:57 AM
mac_24_seven
Jan 31, 2007 03:45 AM
boostincoupe
Dec 8, 2003 09:00 PM
