FITV or IACV or neither?
Old Jun 11, 2011 | 11:09 AM
s2k drifter's Avatar
Default FITV or IACV or neither?
I posted this question on the accord section, should've posted it here 1st. Here's the link...
https://honda-tech.com/forums/honda-accord-crosstour-2003-2012-118/05-accord-idling-issue-2946036/
Old Jun 11, 2011 | 02:27 PM
grumblemarc's Avatar
The Grumpiest
Default Re: FITV or IACV or neither?
So are we supposed to answer it here or in the Accord forum?
You should just have posted the question, in it's entirety, here.
Is that the correct CEL? Fix the issue causing it. Start by performing a full tune up-which you should do first thing after buying a used car.
Old Jun 13, 2011 | 04:55 AM
I was using my iphone. Ill repost it shortly, in the meantime the cel code is P0300, I was told the spark plugs on these cars are good for 120k miles. Also, the car was driving fine and it has 54k miles and I put 800+ miles on it before this problem occured. A friend of mine thinks it's the FITV or the IACV, would that cause cylinder misfire?
Old Jun 13, 2011 | 09:14 AM
Besides checking the plugs, what else should I look into that would cause the car to misfire on this 05 accord?
Old Jun 13, 2011 | 10:31 AM
kyden's Avatar
a blinking CEL means misfire. i suspect you have a bad coil.
Old Jun 13, 2011 | 12:41 PM
You're right, turns out cylinder 4 has a bad coil. Definitely need to get a tune up done on this car. The car is still idling when it heats up, I wanted to remove the tb and remove the FITV to see if it'll solve the problem.
Jessica Woods
Sep 11, 2018 08:40 PM
2.4accord
Dec 3, 2015 07:25 PM
warhawks44
Dec 16, 2012 05:19 AM
jrmymllr
14
Aug 12, 2012 04:35 AM
Mychal71
Sep 13, 2011 02:06 PM
