1997 ITR Clutch
Old Jun 11, 2011 | 10:29 AM
Outlaw-Hondaz's Avatar
Default 1997 ITR Clutch
Car: 1997 Civic hatch w/97 JDM Itr motor
Im looking into buying a clutch kit..(the complete set) and i'm leaning towards Spec and ACT clutches...looking for a stage 3 clutch and i dont know much about clutches so plz giving me some input on what clutch is worth buying....Im a DD and planning to go for Auto-X this summer and fall
Old Jun 11, 2011 | 10:46 AM
FlewByU352's Avatar
Default Re: 1997 ITR Clutch
I just replaced the clutch on my R with an Exedy Stage 2 clutch and the 9.5LB flywheel. I love it as a daily/weekend warrior. Kind of wish I went with maybe a 7LB flywheel though. Little did I know some Japanese guy had the OEM flywheel machined down to 10LBS so I was driving on a lightened flywheel already and had no problems.
Old Jun 11, 2011 | 10:50 AM
what kinda flywheel is it? or the brand name? and how would i know if it's compatible (universal) with a clutch kit?
Old Jun 11, 2011 | 12:01 PM
FlewByU352's Avatar
The Exedy 9.5LB flywheel, I believe it is chromoly
Old Jun 11, 2011 | 12:39 PM
racebum's Avatar
how much boost does the car have? like whp wise?
if there's no turbo there's no reason to move past an exedy stage 1 which by the way is an excellent NA daily driver / autocross clutch. much higher quality design and material than their oem replacement
Old Jun 11, 2011 | 09:41 PM
FlewByU352's Avatar
I think a stock R motor makes between 1-2PSI NA :p And there is a very big reason to go more than the Exedy Stage 1. Both hold the same torque load but the 3 puck clutch of the stage 2 can handle much more abuse. A full face disc is like butter driving, but after some practice I can make daily driving with the stage 2 shifting feel like a CVT transmission. Just gotta know how much the RPM's drop and to change gears right at the next gear up's RPM. I just love the grab of a puck clutch when you launch the car which is why I moved away from a street disc.
Old Jun 12, 2011 | 07:47 AM
what does that mean?
main question : Can I buy any brand flywheel and mix it with another brand name clutch?
Old Jun 13, 2011 | 07:01 AM
94eg!'s Avatar
#1 Super Guy
Loved
Yup, you can mix and match...
Chromoly is a type of steel. It's light and strong. Only trouble is the hardened steel can cause excess wear on your starter gear.
The Fidanza flywheel is 7lbs and made of aluminum. It has a steel friction surface (the part the clutch disc rides against) bolted to it, and a steel ring gear for the starter. Only risk is the multi-piece design could come apart.
Old Jun 14, 2011 | 11:10 AM
thanks
gmadsen100
15
Nov 7, 2006 09:05 PM
f150harleytruck7
35
Dec 16, 2005 09:26 PM
allstockb18c
Jul 3, 2005 12:44 PM
beandip
Nov 23, 2003 11:31 AM
