help gettim my block outta my car
Old Jun 10, 2011 | 05:17 PM
salyboy25's Avatar
Default help gettim my block outta my car
can ne1 tell me what consists of pullin my b20 block from my car without yanking the tranny
salyboy25's Avatar
Default Re: help gettim my block outta my car
or a link to a write up that does explain it
Old Jun 10, 2011 | 05:20 PM
SR20S13's Avatar
it will be easier to pull the tranny and motor out as a unit believe me
Old Jun 10, 2011 | 09:38 PM
salyboy25's Avatar
really??...im thkin about payin someone to do it.... looks like a serious pita....plus nothing but me and a buddys arms to yank it out with
Old Jun 11, 2011 | 01:53 AM
N/A's Avatar
N/A
Purpose Built
Its simple, if you're mechanicly inclined
Where are you located?
Old Jun 11, 2011 | 07:14 AM
kyden's Avatar
pull it with the transmission. it's a lot easier that way.
Old Jun 11, 2011 | 10:54 AM
civichxtreme2's Avatar
Rent a hoist and pull it out whole.
Old Jun 12, 2011 | 09:18 AM
spAdam's Avatar
Loved
Community Favorite
Better yet, Get a hold of a big jack. Lift the car off of the motor.
I like to take mine out the same way it went in at the factory, much easier that way.
Old Jun 14, 2011 | 09:27 AM
salyboy25's Avatar
Ok ive found plenty of how toos on the engine and tranny...thx alot... and is it expensive to rent a hoistor would it be cheaper to get a jack and lift the car...im located down here in gulf shores alabama... not too many of us down here
Old Jun 14, 2011 | 10:59 AM
h22crxpwr's Avatar
you don't own a car jack or jack stands? maybe you should pay someone who knows what they are really doing. you can really hurt or even kill yourself if you don't know what you are doing and the car falls on you or something.
just a suggestion..
Old Jun 14, 2011 | 11:25 AM
C_Rock77's Avatar
Are you palling around with a silverback gorilla?
It's not that friggin hard, Dude. But it's definitely not the 1st project I'd attempt to tackle with a vehicle.
Old Jun 14, 2011 | 12:07 PM
kyosoeg6's Avatar
If u can drop the Tranny separate and you guys are strong enough to lift the motor I say do it that way. If not like someone said above borrow a big *** Jack and just drop it on the ground. If u can manage to take off the shift linkage ithink u can drop this motor onto the ground
Old Jun 14, 2011 | 03:52 PM
madblkscientist's Avatar
droping the motor is easy i did it by myself in 2 hrs with the shift linkage attached becuz takin out the b!@#$ pin is where the work is at
Old Jun 14, 2011 | 04:25 PM
FlewByU352's Avatar
After doing a clutch and flywheel with the motor still in the car, I rather have pulled the whole motor to separate the 2. Huge pain in the *** while both are in the bay. Pulling the motor and trans together as a whole is so much easier. Takes about an hour by yourself at a slacking pace to unbolt, drain, , disconnect and lift it all out.
Old Jun 15, 2011 | 05:35 AM
salyboy25's Avatar
Okay i have a jack just not a big *** jack to hold my motor as i was under the impression i needed... ima just yank it out... and as for the silverback...unfortunately i only have one... but he is usefull...gotta enjoy reading this stuff at 8am at work..
shane
Welding / Fabrication
Mar 9, 2010 11:46 PM
EH2-R
10
Apr 12, 2007 09:45 AM
classciv
18
Jul 31, 2006 06:36 PM
B18EG6
Nov 16, 2002 01:31 AM
Mario
Mar 15, 2002 07:36 PM
