changed transmission in 1991 accord now it turns over but wont start
Old Jun 10, 2011 | 08:46 AM
themachinist1's Avatar
Default changed transmission in 1991 accord now it turns over but wont start
hi all this is my first post and also first honda that ive worked on, so heres the deal i was asked to change the transmission in a 1991 honda accord 2.2, it was trailered to me with some things already dismantled, and the "arts" and transmission in the trunk.
i was able to swap out the tranny and reconnected all the items that i hadnt taken off all except the steering pump which was not there,anyways i found a battery to test the vehicle"also missing", and it turns over fine and shifts through the gears and has spark but i cant hear the fuel pump turn on when i key on the car and there is no smell of fuel on the plugs. i checked all the visible fuses but none of the larger relays, what can be the cause of this and where should i start, ...maybe a test for power to the pump
any hel would be great ive been given compensation already and want the car outa my shop and to see if the trans is good. ill be up late tonight messing so lease stop in and rely
Old Jun 10, 2011 | 10:02 AM
Bwhit12's Avatar
Default Re: changed transmission in 1991 accord now it turns over but wont start
No fuel usually caused by bad main relay. It is located under the driver side dash. That would be my first guess. You can usually tell a bad relay by pulling off the housing and if the soder is in the shape of a hill rather than having a point at the top. You can easily test this by putting in a new relay, turning the key to the on position, and listening for the pump to kick on. Hope this helps you out!
Old Jun 10, 2011 | 08:50 PM
i really kinda thought this too its just odd that they say the car started fine when the trans went out and now that im trying to start for the first time since tranny went, its bad...i hope that it is not something major
Old Jun 10, 2011 | 08:52 PM
im gonna jumper the pump w a 12 v source and see if it comes on
Old Jun 10, 2011 | 09:54 PM
phootbag's Avatar
MIL work?
Old Jun 14, 2011 | 08:16 PM
well I tested the voltage accross the leads on the wires going to the fuel pump and best I got was 5.6-7v so I'm thinking the relay is bad, just so I can confirm this will someone just say yea dude the pump isn't the prob if u only getting 5 +v w key on and that's your main relay!
Old Jun 14, 2011 | 10:48 PM
slomofo's Avatar
GDD Member
http://autorepair.about.com/od/engin...nrelay_tst.htm
Old Jun 15, 2011 | 02:54 PM
phootbag's Avatar
Your dropping about 6 volts somewhere. Could be the main relay could be something else like a corroded connector. Is the remaining voltage drop on the positive or negative side of the fuel pump?
VeroNole08
Nov 13, 2013 06:55 PM
hometheaterman
Sep 13, 2012 11:34 AM
James Olmstead
May 21, 2012 07:26 PM
nova1370
Apr 30, 2012 07:07 AM
WaYtOoLoW
Feb 24, 2010 06:30 PM
