what cams to use???
looking for the best cams for my b16a turbo build ( for drag only ) im looking to try make close to 600hp . so what do ye reccomend or rule out ?
turbo is still not decided but prob go with a gt35r ?
o and i no 600hp is not much for you guys but hey its ireland im from and we are about 10yrs behind on boosted hondas
so any help would be great.
I would recommend using a precision billet 6262 or 6265 with a a/r .82 turbine housing. Journal bearing or Dual Ball Bearing is up to you. Those will be perfect for 525-720ish. It would support more than 720whp but at that number you might be better off going with the Precision billet 6765 because of a much greater torque curve.
whats the most possible hp from b16a ? it will be tuned on a motec m84 and will be sleeved and fully built , im using eagle rods what are these good for ?
Im not sure they're is a limit if money is not a factor. I think eagle claims their rods to 600whp but im sure ppl have pushed past that. I am running Manley I-Beams.
I saw a dyno sheet from jeff evans tuning where a b16 made 800+hp, I heard of a b16 making 900hp. Precision 6262 would be a good turbo for 600whp.
so with pro1s and a precision 6262 now onto the intake .
would the victor x be good enough . i heard about a full-race intake before but never seen one myself anyone any info ? or the magnus ?
yea im after lookin at a few threads here and id say the precision 6262 is looking good . so if i make 600hp and in a car that weights about 800 odd kg with me in it , hopefully ill get some good times , well as long as i head outside ireland.
I'm running the tuner1s which are like ITRs but I've got a street car. If I had a GT35R (600hp) and it was mainly a drag car I'd go Pro1s. Just make sure you degree them before tuning. I hear those are really sensitive.
My car feals good with a stock GSR throttle body, Sk2 intake manifold, CTR cams, and a 6262. Keepin it simple with stock cam gears as well. Numbers in sig..
bring it over to the pod
