**BUILT B20V-tec LongBlock**
SOLD
-B20b Block $1000 Firm
84mm
Cp 12.5.1 Pistons
Total seal rings
Eagle H beam rods
Arp Head Studs
Arp Rod Bolts
Oem Type R oil pump
Oem Water pump
Oem Timing Belt
Golden Eagle Vtec line (-4)
-B16 Head $1000 FIRM
5 angle valve grind intake
3 angle valve grind exhaust
Port an polished
Crower valve springs an retainers
Titanium valve guides
Ferrera 1mm oversized valves
-BLOX B's Camshafts w/
STR Cam Gears $450 Firm
Benen fuel rail $100 obo
440cc injectors $200 obo
84mm
Cp 12.5.1 Pistons
Total seal rings
Eagle H beam rods
Arp Head Studs
Arp Rod Bolts
Oem Type R oil pump
Oem Water pump
Oem Timing Belt
Port an polished
Hey I got a set up just like yours only different cams but same compression!
I made 209whp and 154tq I also got tuned at DNR haha
If it helps with sale I ran a 13.7 on street tires in an integra
Glws dude
Glws dude
