Starting Issue
Old Jun 9, 2011 | 04:10 PM
BlakeMAR's Avatar
Default Starting Issue
I have a 95cx with a B20V swap. Randomly it wouldnt start but it was never that big of an issue because I would just turn the key a couple times or wait a few minutes and it would eventually start just fine. I thought it was the starter relay until I started to hear just the starter gear spin without engaging the flywheel. I began to think it was the solenoid. I removed the started to test it and inspect possible ground problems. I just bought the car and Im growing increasingly unimpressed with the previous owner's general mechanical and electrical knowledge as I had several main grounds that were loose(including the main batt. ground) I also applied a 12v power source to the starter with it out several times to see if it was hanging up or anything and it seemed fine so I put it back in and tightened all the grounds and it was completely fine for a couple weeks, until one day at work it just refused to start again. Does this sound like the relay or the starter? I really hope it isnt the starter since Honda starters are so expensive and I already feel ripped off but thats what I'm leaning towards.
Thanks for any help guys.
Old Jun 9, 2011 | 04:54 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Starting Issue
Can you push start it?
Old Jun 9, 2011 | 05:13 PM
BlakeMAR's Avatar
Yeah it runs just fine, Im just trying to figure out whether its the starter or the starter relay.
Old Jun 9, 2011 | 06:17 PM
vitamin_c95's Avatar
if the starter is spinning and not engaging, it its usually the starter
Old Jun 9, 2011 | 06:28 PM
Former User's Avatar
^this
JPerkMr954
Jun 9, 2013 08:51 PM
patrickstar
17
Aug 4, 2009 07:52 PM
JDM_d15b_eg8
Oct 11, 2007 03:55 PM
rolledthatho
Aug 24, 2005 08:26 PM
