Block/trans dowel pin removal
If you're a long distance commuter like me and replace your engine frequently, you may have had difficulty removing those little locating dowel/sleeves between the engine and trans. They are suprisingly fragile and bend or get buggered up if you try to grasp them with pliers. Mating the engine and trans is hard enough when they are in good shape.
I remembered reading about an old mechanic's trick to pop the clutch/trans-shaft pilot bushing out of a flywheel by packing it with grease, inserting a tight fitting rod and whack it with a hammer to get it to pop out.
Tried this with the dowels and it worked great. Grabbed the right size drill bit out of the index and inserted the shank end in it and used a 2X4 to protect the bit end. The hydraulic pressure pops them right out unscathed.
If they're in the trans like below you can leave em but when they're stuck in the engine block you often want to remove them.
Even if they're $.01 I don't want to make an extra trip to Honda. Dowel pins.. sounds about right. Was too lazy to look it up.
Use a small pliers, take a can of compressed air (preferably not the kind that has bitterant in it, YUCK) and tip it upside down, spray the inside of the dowel quickly, and remove.
Well, it's the proper way to do things. If you don't have them, the motor could shift a little and wear the seals out on the engine and trans or something. It's not that hard to replace a motor. If it wasn't needed, Honda wouldn't have put them on there.
I know how hard it is to replace a motor.
i was told you have to take the flywheel off and then you could get the pilot bearing out.
cause i tryed everything to take that bering off mynes worn out its rough not even smooth idk how to take it out i used greace and a slide hammer nothin worked
radiotech
14
Jul 18, 2018 08:46 AM
93preludeh22
May 25, 2008 09:06 PM
b16spaz
10
Nov 19, 2005 12:42 PM
Fleas_Ef
14
Jan 26, 2005 06:52 PM
