97 civic d16y7 bogs on any throttle!! help!!
okay so a while back my car would stall out while i put in the clutch like at red lights about to go. I installed a walbro 255 later on to set up for boost. car ran great then the next day i stat it up take it down the street and it bogs out, barely even moved. it idles fine but under any and i mean ANY!!! throttle it almost shuts off. so i started with cleaning the tb and iacv and fuel injectors. nothing. i then checked my cap and rotor wasnt to bad so i took light sand paper to them. plugs are changed and gapped. i also changed fuel filter. only CEL codes i get are 10 and 65. 10 because i took of CAI. 65 because i have a 4-2-1 and need to find an extension plug. fuel pressure is around 34-40 but when i hit the throttle it drops almost to zero. all grounds seem fine and good contact. any help is needed!! this is my dd and im in high school
edit: coil is fine, icm is fine, noid light flashes, no longer have cel 10.
maybe i have to borrow a friends multimeter this weekend what should i look for? i know its 0.45v idle and 4.5v wot
The FPR is fine. The fuel pressure, however, should not drop to zero at WOT. Disconnecting the vacuum hose should mimic WOT. If you leave the vacuum hose disconnected for a few minutes, does the pressure eventually drop?
fuel pickup screen in fuel pump may be gummed up... If you're like most high schoolers, leaving the tank near empty allows it to pick up all the junk on the bottom...
i switched the o2 plugs just to see what it would do and i no longer have code 65 i have code 41 should i get o2 sensors? and could that be my problem
