92 integra wiring diagram
Old Jun 8, 2011 | 06:09 PM
evrythng_fast's Avatar
Default 92 integra wiring diagram
can anyone help me out i need the wiring diagram for a 92 integra..asap.
more so the diagram for the turn signals.. im having a problem where the hazards work but the turnsignals dont when i hit left or right on the turnsignal switch on the steering wheel i checked the fuse and its good and just change the turnsignal switch and its still not working.. help????
Old Jun 8, 2011 | 08:13 PM
qpzm12's Avatar
Default Re: 92 integra wiring diagram
have you checked the blinker relay int he fuse box?
Old Jun 9, 2011 | 06:00 AM
fcm's Avatar
fcm
Old Fart
It is not the "blinker relay" or hazards would not work.
Problem is most likely the hazard switch, power for the signal lights go through the hazard switch.
To test/confirm, pull the hazard switch and test for power on the yellow/red, [may be just yellow] with ign. switch on, if there is power on the yellow/red check for power on the green/white, with ign. switch on and hazard switch off] if no power replace switch.
If there was no power on the yellow/red the switch is not the problem, the problem is between the signal light fuse and the hazard switch.
How did you test the fuse?
To elliminate the fuse as the problem replace it with a new or known working fuse, swap it with another fuse, [same size] in the fuse box. 94
Old Jun 13, 2011 | 02:16 PM
i replaced the turn signal switch and still dont work i did replace the fuse with another one same size but i willcheck for voltage tomorrow. where is the blinker relay? is it under the hood with the other relays or under the dash? hey just wondering i got a teal looking wire or light green with a red strip that has been cut under the steering colum do you know what it goes too? theres also another one but dont remember the color it was..
Old Jun 14, 2011 | 06:07 AM
fcm's Avatar
fcm
Old Fart
Again, if the hazard lights work, the "blinker relay" is not the problem, the same relay is used for both hazards and signal lights. 94
Old Jul 8, 2011 | 08:06 PM
okay i know its been awhile since the last time ive been on here but i just did the hazard switch change today and now the turnsignals do work all around front and back and the hazards work.. thanks alot for all your help.
Old Jul 9, 2011 | 03:46 PM
fcm's Avatar
fcm
Old Fart
Have you been driving with no signal lights for a month. 94
Marks accord
Jul 14, 2015 06:30 PM
raffaelli
Mar 7, 2008 06:09 AM
chunkybs
Jan 28, 2008 05:26 AM
TegBen
Jul 26, 2004 04:45 AM
optikal_blitz
Jul 3, 2003 11:11 AM
