HONDA PARTS CHEAP
HELLO I HAVE FOR SALE HERE ALOT OF RANDOM HONDA PARTS. ALL ARE PARTS FROM HONDA CIVIC HONDA PRELUDE AND ACURA INTEGRA.
.MOST EVERYTHING IS "BEST OFFER" EXCEPT FOR THE 5 DOLLAR PARTS IF YOU CANT AFFORD FIVE DOLLARS CANCEL YOUR INTERNET!!!
B SERIES:
CLUTCH PRESSURE PLATE AFTERMARKET DUAL FORKED HEAVY DUTY 25.00
GSR FLYWHEEL 30.00
A/C BRACKETS
P72 GSR NO TENSIONER 10.00
P73 TYPE R no tensioner 20.00
P/S BRACKETS P73 TYPE R UPPER 15.00
P54 LOWER 5.00
DRIVER MOUNT BRACKET ON BLOCK 15.00
EXHAUST MANIFOLD GSR WITH B PIPE 30.00
P72 GSR UPPER REAR TIMING COVER X2 5.00
MOROSO SPARK PLUG WIRES RED LIKE NEW 50.00
D SERIES:
P/S PUMP OBD1 AND OBD2 15.00 EACH
P/S PUMP BRACKET OBD1 P28 5.00
A/C BRACKET OBD1 AND OBD2 5.00
TRANS TORQUE BRACKET 5.00
REAR TRANS T BRACKET 5.00
D16Z6 EXHAUST MANIFOLD 10.00
1997 CIVIC HX DISTRIBUTOR 60.00
H SERIES:
H22A1 OBD1 POWER STEERING PUMP 25.00
H22A4 OBD2 POWER STEERING PUMP 30.00
H22A4 EXHAUST MANIFOLD 25.00
H22A4 U/L TIMING COVER 30.00
H22A OE WATER PUMP LOW MILES 20.00
H22A4 TYPE SH ATTS UNIT 50.00
H22A4 TRANSMISSION 200.00 needs bell housing replaced i will throw in perfect bellhousing or i will have it fixed and sale for 400 no grinds on broken bell housing!!
H22A HARMONIC BALANCER 30.00
H22A OBD1 BALANCE SHAFT GEAR 5.00
H22A OBD1 TIMING BELT GEAR 5.00
H22A1 OBD1 ALTERNATOR 30.00
H22A4 OBD2 ALTERNATOR 40.00 X2
H22A1 4TH GEN TRANS MNT W/ BRKT 15.00
MISC PARTS:
92-95 CIVIC POWER STEERING PRESSURE HOSE 20.00
92-00 CIVIC RIGHT REAR UPPER ARM 5.00
92-95 CIVIC CHARCOAL CANISTER FREE WHEN BUYING SOMETHING ELSE
92-95 CIVIC STOCK AIR BOX SAME AS ABOVE
92-95 CIVIC DOOR GLASS 2DR & HATCH 20.00EA
97-01 HONDA PRELUDE STOCK AIR BOX 15.00
97-01 PRELUDE UP STRUT MNTS AND FORKS 30.00 ALL
PLEASE CALL OR TEXT WITH ANY INFO NOT LISTED PLEASE DONT WASTE MY TIME WITH NONSENSE I AM A VERY BUSY PERSON AND DONT HAVE TIME FOR THE NONSENSE. AS STATED ABOVE PRICES ARE ALL OBO
469-360-8420
B SERIES:
GSR FLYWHEEL 30.00
A/C BRACKETS
P54 LOWER 5.00
D SERIES:
H SERIES:
MISC PARTS:
469-360-8420
miraclehonda
Nov 9, 2008 04:40 PM
