idling problem
just recently swapped a b16 and when car is cold and i start it and let it idle, the rpms jump up and down. it'll lag and then go back up. not exacty sure what it is. any suggestions or ideas on what's goin on??
Up/down idle is NOT normal. If you do a search on this subject you'll find at least 100 hits about idle problems. In most cases they are caused by a vacuum leak, faulty Fast Idle Valve, a clogged base idle adjustment screw, low coolant level, mis-routed vacuum lines, or harness plugs swapped between sensors.
joelmatt89
13
Mar 9, 2009 07:03 AM
