How do I CONVERT AUTOMATIC Integra to MAUNAL?
Old Jun 8, 2011 | 12:14 AM
ayang89's Avatar
Default How do I CONVERT AUTOMATIC Integra to MAUNAL?
I have a 94 four door integra thats a automatic that I would like to make a 5speed stick shift. What would I need and do to make it a 5 speed? Thanks!
Old Jun 8, 2011 | 12:49 AM
Mouanology's Avatar
Default Re: How do I CONVERT AUTOMATIC Integra to MAUNAL?
I personally don't know, but I do know that if you bought a manual integra in the first place it probably would have been cheaper than a conversion.
Old Jun 8, 2011 | 01:06 AM
TypeRMOBBiN209's Avatar
search
Old Jun 8, 2011 | 07:30 AM
GagnarTheUnruly's Avatar
Unless you've got a lot of money in the car or have sentimental attachments you should probably just sell it and buy a manual. You could easily get a GS-R and still be miles ahead financially.
Old Jun 8, 2011 | 09:41 AM
BigDaddyRich's Avatar
^^^ Not true. I just picked up my 2nd Integra a few months ago, and for the most part the manual cars I went to see were beat to **** and pieced together, by what seems like broke H-T or B20V forum folks Most of the auto's I saw were 99% original & OEM clean, just needing basic maintenance. I bought a commuter 96 Auto LS that I will be converting one of these days. Automatic cars seem to be not as beat a tuner/street racer/ forum junkie manual cars.
Old Jun 8, 2011 | 09:45 AM
From what I gathered.
Tranny/Flywheel and clutch setup.
Shifter Linkage
manual tranny mount & subframe brace
Axles & intermediate shaft.
obviously, pedal(s) clutch master, slave and clutch line.
Interior trim
Im sure Im missing other minor stuff
Old Jun 8, 2011 | 09:46 AM
Mouanology's Avatar
You know what.. Now that I think about it your right
Old Jun 8, 2011 | 11:49 AM
EJ1_CRIS_909's Avatar
Ya all the autos seem to be the unmolested reliable cars, so switching one to manual is time consuming, but wouldnt be a bad idea.
Your also gonna need a new manual ecu.
Old Jun 8, 2011 | 11:58 AM
I still don't think it's worth the money. I wouldn't even consider it unless I was convinced I couldn't find a decent condition MT car in my area.
But I haven't looked in a long time. Maybe they are really hard to find
Old Jun 8, 2011 | 06:52 PM
JOE_DC4ever's Avatar
Shifter Linkage
Interior trim
Also to add to this list,
MT ECU
you might have to modify shifter hole in the floor, but might be able to get by with a short shifter
flywheel bolts
center console
gauge cluster is nice if you don't want the auto one
you have to run wires for the reverse lights
IM might need some tweeking for it to work on a MT(I think they maybe slightly different but forget how exactly)
yada yada yada
Ive done it before on a civic and I wouldn't do it again. It ends up being more money and time and effort than you initially expect and you end up with a car that doesn't feel the same as an original manual (probably for me because im OCD and know that it was an auto even though no one else can tell). IMHO, wait for a decent MT integra and get that instead.
Best of luck to you whichever route you take...
Old Jun 8, 2011 | 07:02 PM
91b18a1ls's Avatar
My 92 da was converted before I bought it so Idk what the guy actually did, but he said it was a pain in the *** and took some time. I kept my auto cluster though, gives it some personality
Old Jun 8, 2011 | 11:27 PM
ayang89's Avatar
Yup, I agree. All the manual transmission integras around here are either beaten to death or been molested. The only REAL clean integras ive seen lately are ALL the automatic ones.
Old Jun 8, 2011 | 11:28 PM
ayang89's Avatar
Moneys not really an issue. Its all Government money baby! ( Im in the USMC ) There not hard to find. its either there Riced out or Beaten up
Old Jun 9, 2011 | 01:09 AM
Apathy47's Avatar
There's a few threads available with everything you need to know:
Even though this DIY is for a Civic, the concept is the same with a few differences.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-96-00-auto-manual-swap-full-detail-44pics-1337459/
DIY for Integra but without images.
https://honda-tech.com/forums/acura-integra-6/auto-manual-swap-should-sticky-1255332/
Parts List
https://honda-tech.com/forums/acura-integra-6/auto-manual-parts-list-273253/
The rear T-bracket of an Integra is the same auto or manual. If I'm wrong then correct me but I'm using the same T-bracket from my automatic longblock and it bolts right up to my manual transmission...
It's the transmission mount that needs to be changed since the automatic chassis post-mount sits higher than a manual chassis.
I did a auto to manual conversion on my 96 Integra so feel free to ask me a question. Just research these few threads and get the necessary parts and you're good. Good luck!
RizoHatake
Sep 11, 2018 10:45 AM
jdmboss
Aug 6, 2008 11:15 AM
