OBD2 B16 -- can a throttle body sensor make a car run slow
Old Jun 7, 2011 | 07:18 PM
jdmeg6honda's Avatar
Default OBD2 B16 -- can a throttle body sensor make a car run slow
i installed a skunk 2 throttle body and i cant get it to the stock spec and the car runs like slow sometime it runs good but the check engine lights stay on
Old Jun 7, 2011 | 07:25 PM
Former User's Avatar
Default Re: can a throttle body sensor make a car run slow
Code?
Old Jun 7, 2011 | 10:33 PM
THC07's Avatar
seriously!
your light is on and you're asking questions?
Old Jun 8, 2011 | 12:23 AM
the code are air idel control and throttle body sensor first the air idel control code pop up and ran slow and stupid and now the throttle body sensor.. and seriously if the check engine lights come on doesnt make the car go slow all the time it some time make it run rich and better duhh..
Old Jun 8, 2011 | 02:27 AM
BryanM.'s Avatar
Resident Gearhead
lol no
Fix the CEL codes and go from there.
Old Jun 8, 2011 | 06:21 AM
sohctodohc's Avatar
your grammar is that of a 6 year old...
Old Jun 8, 2011 | 08:34 AM
THC07's Avatar
More fuel does NOT mean its going to make your car faster.
Last edited by Former User; Jun 8, 2011 at 08:51 AM. Reason: Flaming posts are forbidden in tech forums. Please review the forum rules.
Old Jun 8, 2011 | 08:44 AM
that_boy_sammy's Avatar
Your throttle position sensor? From when I installed it theres only one way to put it on. And if you bought a skunk 2 tb it is already calibrated. Find out your cel code, fix it, and it will not run sluggish.
Old Jun 8, 2011 | 09:35 AM
Crashtestdummy's Avatar
Old Jun 8, 2011 | 09:51 AM
Please do not derail tech threads with off topic comments. While I don't classify these posts as flaming, such comments should also be accompanied by an attempt to help with the tech problem. Otherwise, they don't serve a very good purpose.
Old Jun 8, 2011 | 12:49 PM
the skunk 2 throttle body came with no sensor meaning no map or throttle body sensor and i put on all the sensor but the throttlebody sensor might be wrong bcuz i couldnt get it to stock spec...
Old Jun 8, 2011 | 01:00 PM
You need to calibrate output voltages from the TPS. Also immediately pull the CEL codes. Click the CEL link in my signature.
Old Jun 8, 2011 | 01:20 PM
its a obd 2 b16 so whats the output voltage on that thing? and how do i know if i got a bad throttle body sensor?
Old Jun 8, 2011 | 01:23 PM
0.5V closed throttle, 4.5V WOT
Seriously, before you make anymore posts, jump the service connector to pull the codes. Then post them.
What car?
Old Jun 9, 2011 | 10:33 AM
Default Re: OBD2 B16 -- can a throttle body sensor make a car run slow
ok i cant find the jumper wire so i used my obd 2 scanner tool and the code are tps and air idle control...
ok so this is what i did changed to a brand new air idle control and the adjust the tps.
this is how i did it turn the car to on position adjust w.o.t 4.50v and closed was 0.32 volts. and i turn the car on and it was still the same 0.32 i adjust the idle screw on the throttle body and no luck am i doing something wrong?
Old Jun 9, 2011 | 01:20 PM
Post the two OBD2 codes.
Or are the codes now gone?
The correct calibration procedure is to adjust the voltage to 0.5V at closed throttle and then to check that the voltage is around 4.5V at WOT.
Old Jun 10, 2011 | 11:26 AM
i pulled off the battery cable so the codes is gone but will return in a few days ..
so let me get this rite i gotta check voltage at closed first then w.o.t and not at w.o.t then closed idle?
ok imma try closed first then w.o.t
Old Jun 10, 2011 | 01:25 PM
Yes. First adjust closed to 0.5V and then just check the WOT voltage.
Old Jun 15, 2011 | 07:24 AM
THC07's Avatar
How are you adjusting your TPS?
an .45v closed and 4.5v WOT is probably the best you will be able to get.
just askin; you did change the TB gasket with a new one when you installed the Sk2 TB, yea?
2005del*6*
Honda CR-V & Element
Feb 11, 2013 04:10 PM
SkyliteCustomz
Honda Civic (2001 - 2005)
Nov 12, 2007 01:59 PM
b18c1wes
Dec 7, 2004 02:50 PM
SuzukaBlueAP2
Oct 16, 2003 02:39 PM
D1ANCER
Mar 27, 2002 06:06 PM
