Ebay OBX Racing Headers Tri Y b18c, too low? (pics)
Old Jun 7, 2011 | 06:01 PM
ChrisSmilesBack's Avatar
Default Ebay OBX Racing Headers Tri Y b18c, too low? (pics)
Hi i was wondering if you all think these headers sit too low to the ground, i would hate to break my flange off. Or is this a normal aftermarket/Ebay pile o crap fitment. I am ok w/ it, but i am getting 3" back put on soon and i wanted to make sure.
Plus there are no pictures of obx r racing tri y headers for b18c on the internet so here they are.
does not fit w/ h brace
JEEZE thats alot of photos.
Old Jun 7, 2011 | 06:08 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Ebay OBX Racing Headers Tri Y b18c, too low? (pics)
That's pretty low. One good speed bump would do it.
Old Jun 7, 2011 | 07:01 PM
Think i'm going to chop the middle bar out of the H brace.
Old Jun 7, 2011 | 07:13 PM
The Grumpiest
Then that would weaken the structural rigidity of the part. You might as well not even put it on. I installed my brace on my hatch with stock exhaust because it wouldn't clear the downpipe on my coupe. I wasn't about to try and modify the brace to fit.
Old Jun 8, 2011 | 08:01 AM
Red_Army's Avatar
thats super low.
does it hit the flange or the piping?
Old Jun 8, 2011 | 10:12 AM
hyperblu's Avatar
Im pretty sure the pics will answer your question... A slight speed bump and your flange is toast...
Old Jun 8, 2011 | 11:34 AM
igorka_91's Avatar
Weird how no one caught the problem here. Notice were the slip joint connect. Your problem is that you tightened it to hard wich is causing it to be pulled toward the ground because there are no bolts on the top of the pipes. Untighten those bolts and se if the collector would go up. Also if you have access to a welder. I would weld those collector joints how you want them to sit at what ever height. Hopefully OP gets what i am saying. I had the same issue with my hytech knock of small tube tri-y header.
GL
Old Jun 9, 2011 | 07:59 AM
Red_Army's Avatar
i now see what you were getting at.
won't hooking up the exhaust help lift it back up too?
Old Jun 9, 2011 | 10:16 AM
igorka_91's Avatar
Nope. The exhaust holds on those rubber things so all its gonna do it putt it down. And then all of the exhaust will be all weird looking plus the muffler in the back will be pointing up a lill.
Old Jun 9, 2011 | 12:58 PM
NotAJDMFanBoy's Avatar
What motor do you have? If you have a B16, then it would make perfect sense since the B16 has a shorter deck height and the exhaust will sit lower as a result.
The only fix would be getting a header that fits, or cutting the header and using a little persuasion to make it fit.
N2RCN4FUN1
Oct 3, 2015 08:20 AM
94IntegraLs04
Mar 9, 2005 09:02 AM
opkjoblacsh
16
Oct 16, 2004 11:01 PM
RallyRedGT-V6
May 1, 2004 03:57 PM
Thrillhouse
Jul 23, 2003 07:53 AM
