Erratic Idle. Air in cooling system?
Old Jun 7, 2011 | 05:35 PM
strider380's Avatar
Default Erratic Idle. Air in cooling system?
I put my 99 Honda civic EX motor in a 96 civic. I've been driving it every day for a few months, but since day 1, its had an erratic idle at start up. I did some reaserch and found it could be a dirt IACV or air in the cooling system. I cleaned the IACV and it did nothing. Makes sense because it didn't have an erratic idle when the motor was in my last car. I obviously disconnected my cooling lines however when I did the swap. Can someone tell me how to check for/alleviate air in the cooling system? I have no idea.
Old Jun 7, 2011 | 07:05 PM
Former User's Avatar
Default Re: Erratic Idle. Air in cooling system?
Any CEL codes?
Have you checked for vacuum and intake air leaks?
Bleeding the cooling system may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
Old Jun 7, 2011 | 07:15 PM
95EG2's Avatar
a bad iacv... same problem with my hatch i use to have
Old Jun 8, 2011 | 01:03 AM
virgineg6's Avatar
i dont know if this engine has one but since you said only at start up have you tried adjusting/ cleaning the fast idle throttle valve (fitv)?
Old Jun 9, 2011 | 06:31 AM
strider380's Avatar
I kind of looked into the fitv but not sure if this motor has one. was unable to find one anyways. I swapped the IACV for another one that didn't have an erratic idle either. and still same problem.
there are no CEL codes and i don't think theres any vaccum leaks, thoi'll check again. Intake? you mean the intake manifold gasket? don't think I ever took the intake off so it should be fine. I did take off the exhaust manifold. what would a leaky exhaust manifold cause?
If there was air in the cooling system, wouldn't it find its way out after several months?
Old Jun 9, 2011 | 06:37 AM
grumblemarc's Avatar
The Grumpiest
No FITV on that engine.
Nope. Take the 20-30 minutes to bleed it. Air can cause erratic idle and overheating.
Da_1991
Apr 8, 2014 09:01 PM
torinharrington
Jun 14, 2013 07:29 PM
Esprit09
Jun 7, 2011 03:27 PM
mcchau01
Aug 2, 2005 12:31 PM
NightHawkC5
Jul 31, 2003 09:23 AM
