P1337 - wiring problem? need help!
Old Jun 7, 2011 | 05:05 PM
DanDaMan559's Avatar
Default P1337 - wiring problem? need help!
Hey guys, I recently bought a 99 si, it has a b16a2 wit a obd1 gsr Ecu, I decided to put the stock si Ecu, obd2b, on the car but I immediately got cel p1337...it was running ok for a few miles but now it stalls as soon as I turn on the car, ifi press on the gas it stalls evrn faster...the gsr ecu still makes the car run ok...could this be a wiring issue? Btw the gsr Ecu is chipped, don't know with what...thank you!
Old Jun 7, 2011 | 05:31 PM
civic-steve-94's Avatar
Default Re: wiring problem? need help!
P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
i dont know if this helps im having wiring problems too but i found this laying around on a thread here
Old Jun 7, 2011 | 05:34 PM
Thanks yea I caught that too, strange thing is I no longer get cel light, my car just stalls...
Old Jun 7, 2011 | 07:06 PM
well than if there is no cel then its something mechanical have you disconnected the battery for like 20 minutes
Old Jun 7, 2011 | 07:10 PM
grumblemarc's Avatar
The Grumpiest
If you don't know what the ECU s chipped with then why are you running it? Get a stock ECU and try that.
Old Jun 7, 2011 | 07:22 PM
The si runs with the chipped ecu, but not the stock ecu
Silverdrifter07
Engine Management and Tuning
Sep 13, 2016 12:18 PM
NVMYDC
Dec 29, 2010 10:52 PM
civic89si666
12
Jan 6, 2010 02:05 PM
Tylerjdmgsr
Sep 6, 2009 12:13 PM
Turboholic
Aug 25, 2004 07:16 AM
