fuel pump doesnt prime all the time
Old Jun 7, 2011 | 04:37 PM
cdmed6si's Avatar
Icon6 fuel pump doesnt prime all the time
i have a 91 dx hatch and 1/30 times i goto start the car the fuel pump fails to prime. no whir click from the fuel pump priming. is it time to get a new one yet or is it just the nature of the 20yr old car?
Old Jun 8, 2011 | 06:42 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: fuel pump doesnt prime all the time
What does a car being 20 years old have to do with anything? It should still function as it was intended to. Most likely it is your main relay because fuel pumps typically don't fail then magically start working again.
Old Jun 8, 2011 | 10:03 AM
racejunke13's Avatar
Main relay
Old Jun 8, 2011 | 10:06 AM
97ludedude's Avatar
Originally Posted by racejunke13
Main relay
X3
Old Jun 9, 2011 | 05:24 PM
cdmed6si's Avatar
ive checked the main relay already because i was having trouble with the distributor
Old Jun 9, 2011 | 05:37 PM
DO IT ON ALL FOURS
Ok - so what are you doing, just turning the key back and forth? How much time between key cycles?
Old Jun 10, 2011 | 10:15 PM
cdmed6si's Avatar
back and forth yes for the first couple tries then its pull it out set the keys on the passenger seat wait five seconds try again if all else fails i wait long enough to smoke half a cigarette usually starts then again sometimes takes a full cigarette
Old Jun 10, 2011 | 10:45 PM
lazy14's Avatar
believe it or not but my map sensor went bad n mine didnt prime, jus another suggestion, mines also obd1 if that makes a diff
Old Jun 11, 2011 | 12:50 PM
DO IT ON ALL FOURS
The prime isn't supposed to work like that. Some fuel systems leak down fast - some slow. Either way you fuel system should hold pressure for some time if not indefinitely. The purpose of the prime is to get the system up to pressure for a start and then shut off. If you are just flipping the key back and forth and your fuel pump primes everytime then your fuel system has a MAJOR internal/external leak.
So as long as it starts every time don't worry about it - your system is working correctly. If it doesn't start and you hear no prime - then you have problems.
Old Apr 17, 2012 | 09:18 PM
cdmed6si's Avatar
It was the battery terminals one was almost split in half
StegRX
Feb 8, 2016 07:54 AM
Nicholas Harvey
Jul 16, 2013 01:55 AM
JimmyM86
15
Oct 18, 2007 08:44 PM
bogus_ek
Jun 4, 2004 10:18 AM
Heavy Pee
Nov 22, 2003 08:01 AM
