Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
blower motor
Old Jun 7, 2011 | 10:21 AM
jaychande's Avatar
Default blower motor
I have Honda civic 1.7 ctdi and have a problem with blower not working.the fan works if direct 12v given but no power coming through the wires connecting the blower.Can anybody help ?
Old Jun 7, 2011 | 10:38 AM
husyk's Avatar
Default Re: blower motor
For a second there I thought you a D17 with a blower on it. Possible blown fuse or loose connection.
Old Jun 7, 2011 | 11:15 PM
It Wasn't Me's Avatar
Please Search before you make a thread.
https://honda-tech.com/forums/honda-civic-2001-2005-78/new-here-got-c-problem-died-2891710/
https://honda-tech.com/forums/honda-civic-2001-2005-78/need-help-blower-motor-problem-2756212/
There are more threads on the subject, but you'll need to search for them.
Old Jun 8, 2011 | 01:16 AM
jaychande's Avatar
Thanks husky but fuse is fine and not loose
.(It Wasn't Me) your links seems good and i will go through them.However can one repaper the resistor? I wish i had seen it earlier but being new to the site i am not quite sure how to go about it, but getting there slowly.Thanks once again.
Old Jun 8, 2011 | 12:28 PM
Originally Posted by jaychande
However can one repair the resistor?
repaper.. lol
I assume you're referring to the power transistor. Click the following links from the FAQ's..
Testing the Power Transistor: Link
Fix A/C Power Transistor: Link
You might want to read this one, too.
Retrieve HVAC DTC's: Link
Old Jun 13, 2011 | 12:43 AM
jaychande's Avatar
Many thanks for the ones who tried to help, I finally sorted it out by changing the fan resistor second hand though.I was told all models from 2001 to 2005 civic use the same resistor and i took a chance and changed it off a 20020model and it is working fine.Thanks guys.
Old Jun 13, 2011 | 12:49 AM
jaychande's Avatar
By the way it only costed me £30 instead of £120 quoted by Honda garage.
myers503
Nov 10, 2013 09:21 AM
PaChiLa Leader
Apr 26, 2013 12:19 AM
caseyk00
Oct 19, 2011 02:26 PM
Lambo123
Jan 9, 2009 11:25 AM
judyj
Aug 4, 2002 12:03 AM
