96 Civic transmission fluid and timing belt
Old Jun 7, 2011 | 10:04 AM
mcd7's Avatar
Default 96 Civic transmission fluid and timing belt
I'm going to be changing the transmission fluid in my 96 Civic as it hasn't been done for sometime now. I read that you must use Honda ATF for this transmission. Can I substitute the Honda ATF for a good quality Dexron III? The Honda ATF is more than twice as expensive as a good quality name brand ATF. Also, I'm going to be changing the timing belt, tensioner and water pump since I don't have any records of it being changed recently. I would like to get a kit that includes everything I need. Someone suggested Contitech and they have a kit for around $100. Is it any good?
Old Jun 7, 2011 | 02:45 PM
mcd7's Avatar
Default Re: 96 Civic transmission fluid and timing belt
Anyone?
Old Jun 7, 2011 | 02:54 PM
lordhelmet1584's Avatar
Just go oem. The dealer will bag everything up for you so you can have a kit.
Old Jun 7, 2011 | 04:22 PM
redm3turbo's Avatar
I used max life valvoline -- for atf fluid.
For the timing belt.... Id get the OEM one. You can find em on ebay with tensioner and water pump, for like 60 bucks last time I looked...
Old Jun 7, 2011 | 04:34 PM
Blacknight117's Avatar
I would say stay with OEM. It may be more expensive, but at least you know it will last.
Old Jun 7, 2011 | 04:43 PM
98civdx's Avatar
Master Detailer
OEM timing belt and water pump. It can be found on ebay for $149 w/out tensionor.
I bought one it came with all 4 belts, water pump, cam seal, and oil seal. $149 shipped. The tensionor can be found for another 40-50 bucks for OEM as well.
EK9JSPEC
Aug 3, 2012 03:58 AM
98civdx
29
May 2, 2011 07:04 PM
kelviiv
Jun 5, 2010 10:02 PM
92integraVTECgsr
Jun 4, 2005 03:31 PM
90Integra
Nov 2, 2004 12:11 PM
