Trouble Starting Car
Well my Eg hatch equipped with an LS V has been down for 4 months now. But before i went into construction, the motor was running fine nothing was wrong, i made sure everything was perfect before i began starting on the project. Okay so now everything is back together, never took the motor apart. So as i crank it, it turns over but no start. But when i add starter fluid it starts up a bit then dies. I have cel code 16 (fuel injection) and 22 (vtec pressure switch). Fuel primes clearly. Did wire tuck, and thinking it was the wires that i messed up i took everything apart and checked all the soldering but nothing was wrong or loose. I was thinking that it could be the valve cover ground not having enough ground to power the injectors. Idk, any thoughts? Thanks.
Yup. but what i dont get is that im not getting spark from my distributor. Changed the guts in the distributor and still the same results. But it cranked up before and started for a second then died. Tried the distibutor on my friends car and works just fine.
skribblez
12
Aug 27, 2006 05:51 PM
