Removed Turbo.
Old Jun 7, 2011 | 01:29 AM
jfidelh's Avatar
Icon2 Removed Turbo.
Hello guys, So I decided to remove the turbo off of my 98' Accord LX. Too many things and $$ to keep up with. Havent driven it for weeks since i havent found a place to get it tuned so thought this would be the best decision.
So far I have removed the headers / turbo / downpipe. I will be getting the headers tomorrow and will be buying an air intake as well.
Are there easy ways to seal off Oil return that was welded onto the oil pan and the oil feed line?
As far as im concerned these are the only things I need to do to it right? And I can drive it without doing anything else to it?
If im wrong please comment on what else I need to do. Thanks
Old Jun 7, 2011 | 06:44 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Removed Turbo.
Put in the stock injectors and ECU.
Old Jun 7, 2011 | 03:29 PM
jfidelh's Avatar
ECU done, but stock injectors? Can I leave the ones it has on now? also the turbo manifold didnt have a O2 sensor fitting but the oem one does, and i cant find where to connect it to?
Old Jun 7, 2011 | 07:20 PM
The Grumpiest
If you're not tuned for bigger injectors then put the stock ones back in. No O2 sensor? How are you not throwing codes?
Old Jun 8, 2011 | 12:38 AM
jfidelh's Avatar
I was mistaken, On the old downpipe the sensor was located near the cat and on the oem one it is located under the manifold shield. Lol I went to home depot, ace harware and autozone looking for a thing to cover it up for now and a Sparkplug from an old school car did the trick $2.18 then when i went to plug the sensor at the bottom i realized there was no bottom plug for the new downpipe haha.
Just throwin codes for TPS. Ima get it from a scrap yard for $50.
Old Jun 8, 2011 | 01:07 AM
TypeRMOBBiN209's Avatar
i got a blox tps off ebay for 10
Old Jun 8, 2011 | 01:39 PM
jfidelh's Avatar
It's 50 because I have to buy the whole throttle body tho :/
I read about people drilling out the screws? If you know about that @TypeRMOBBiN209 can you help me out with more info. please.
Old Jun 9, 2011 | 01:17 AM
here you go i just explained to the guy in this thread
https://honda-tech.com/forums/acura-integra-type-r-8/throttle-body-tps-questions-2940595/
Adam Bird
Jan 5, 2016 01:14 AM
skaraider
Jun 8, 2012 04:41 AM
dsturch1
Jun 18, 2010 07:19 PM
Hanmin
14
Jun 8, 2008 07:18 PM
the jdmchop
May 19, 2005 10:29 AM
