GARRETT 60mm .81 A/R P-Trim ok for H22A ?
I am gettin a pretty good deal on a Garrett 60mm with a .81 a/r exhaust side P-Trim and I would like to know if this would be a good turbo for my built H22A with a power goal of about 450Whp?
H22A is 9:1 CR closed deck with Mahle Pistons, Eagle Rods...
I have a p trim turbine it made 360 whp on 12psi. Check how big the compressor wheel is and poat the specs or at least how much it flows
Oh and its out of a late model Mustang kit and it has a T4 flange with less than 2k miles on it - thats all I know right now...
I think its 60mm and has a 3" V-Band exhaust side mount (my current downpipe is also 3" - just gotta put a v-band flange on) - I am assuming this would be a nice turbo for a built H22A? ...
FWIW I had a P trim 61MM precision PT 6176 (The P-trim means 76mm exhaust wheel) on my first itteration of my pile of ****.
Made 620 WHPand 450 TQ on Trick 110 at 26 PSI when the compressor maxxed out. Is this an S or E compressor cover (3" 50-60 AR inlet or 4" .70 AR inlet)???
Its not going to make 700 at the wheels like they say, but you should beable to make 6 no problem. Yes, its an S cover and yes its PERFECT. ;O)
the.hamburglar
May 13, 2006 05:55 AM
thanks for replying bro! Yeah I think I'm gonna go ahead and get it.
