A/C GETS WARM AND FAN SLOWS 2003 CIVIC EX
MY daughters 03 civic a/c went out last year. Just replaced the compressor, dryer, expansion block. Cools fine but the compressor wouldnt shut off, so I cut the wire to the switch on the dryer and installed a switch on the inside. Took a trip over the weekend (about 90 degrees out side), and about one hour in the air started getting a little warmer and the fan slowed. Turned the air off, and when she turned it back on,
it was fine. On the way back the same thing. I asked if she was running the max, and she said yes. I had her turn max off and it worked fine the rest of the trip.
Souds like the evaporator is freezing up. Any Ideas?
it was fine. On the way back the same thing. I asked if she was running the max, and she said yes. I had her turn max off and it worked fine the rest of the trip.Souds like the evaporator is freezing up. Any Ideas?
You should read through this thread. https://honda-tech.com/forums/tech-misc-15/%2A%2A%2Aair-conditioning-c-guide-how-works-when-doesnt%2A%2A%2A-2900177/
J...H22
80
Feb 11, 2014 05:29 PM
pcu
14
Aug 24, 2011 05:21 PM
julioboostamante
11
Jul 23, 2010 10:28 AM
